10-03-2010, 05:17 | #5 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Paradise on Earth
Member: 1281866 Status: Offline Thanks Meter: 330 | First check shorting on battery connector if normal flash with any latest version do factory settings .Tested by me many times try and post results also check battery in most cases i solved the problem by flashing best of luck |
10-03-2010, 07:37 | #6 (permalink) |
Freak Poster Join Date: May 2007 Location: mumbai
Member: 504441 Status: Offline Thanks Meter: 29 | DEAR 1st CHECK SHORTING,AND CHECK THAT BLUETOOTH IC IS HEATING OR NOT, IN 2760 CASE NORMALLY BLUETOOTH IC IS SHORT,IF BLUETOOTH IC IS HEATING THEN CHANGE BLUETOOTH IC.TRY AND REPLY..GOODLUCK.. |
Tell me any kind of se problem,i will tery to solve it only in 3 hour........ | roney_nexus | Sony Ericsson | 1701 | 05-17-2017 09:45 |
N-73 batt finshed in 6 hours | Yassen | Nokia Hardware & Hardware Repair | 3 | 05-13-2009 07:26 |
UNLOCK 3 FOMA M702iG IN HALF HOUR | maplegsm | Smart-Clip | 10 | 03-31-2008 07:41 |
3210 discharges battery in 3 hours | baz_thrower | Nokia Hardware & Hardware Repair | 3 | 12-30-2002 03:15 |
