Old 11-12-2006, 13:09   #1 (permalink)
nomi's Avatar
Member: 78440
Thanks Meter: 56
nokia 3230 display problem
hi to all, i have nokia 3230 with white display problem. i chenge the lcd and uper bord but problem is same.any body have slution for my problem
The Following User Says Thank You to nomi For This Useful Post:
Old 11-12-2006, 13:19   #2 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
first of all you shud chek call incoming and outgoing if ok then chang the display ic if call incoming and outgoing is not ok then problem is sofw
Old 11-12-2006, 15:08   #3 (permalink)
Member: 350571
Thanks Meter: 920
3230 Lcd Ic
Change This Ic Good Luck
The Following 5 Users Say Thank You to sree krishna For This Useful Post:
Old 11-23-2006, 10:05   #4 (permalink)
Member: 172261
Thanks Meter: 364
i've change this display ic, ui board, lcd still same
my lcd, ui board test on other 3230 still working
how to solve???
this phone when i receive is light problem (lcd no light but still can see the words on lcd) after i make jumper (some trick find in forum) still no light
at last i find the lcd connector in ui board broken 1 line, after connect it back light work fine but now display problem
Old 11-23-2006, 19:44   #5 (permalink)
Member: 320354
Thanks Meter: 48
check ur broad that 3 connetor
90% sure u connetor damage~
use that new UI board
try check and change
and post result
Old 11-24-2006, 03:12   #6 (permalink)
Member: 172261
Thanks Meter: 364
and post result
the ui board already changed
do you mean these 3 part connector in main board
The Following 3 Users Say Thank You to andre128 For This Useful Post:
Old 11-24-2006, 03:57   #7 (permalink)
abskie's Avatar
Member: 339146
Thanks Meter: 2
and post result
the lcd and ui board is working in other 3230!
Old 11-24-2006, 08:08   #8 (permalink)
akkaamgopi's Avatar
Member: 247683
Thanks Meter: 49
Thumbs up 3230
Hi Br.
Try to change display ic
Old 11-24-2006, 11:15   #9 (permalink)
Bagscom's Avatar
Member: 319976
Thanks Meter: 14
try to change voltage regulator or zucos
The Following User Says Thank You to Bagscom For This Useful Post:
Old 11-24-2006, 13:10   #10 (permalink)
ics_igrec_zet's Avatar
Member: 55427
Thanks Meter: 7
M8 all u need to do is change the display connector from the board.
BR, xyz
Old 11-24-2006, 21:00   #11 (permalink)
Member: 320354
Thanks Meter: 48
ya change it that 3 part connector
Old 11-29-2006, 10:30   #12 (permalink)
Member: 172261
Thanks Meter: 364
damn it.......
today another 3230, i just remove housing clean the joystick, still no replace... suddenly no light... only can see picture/words
i follow this http:///vbb/attach...4&d=1164334347
the main board become hot... no working...
any solution???
Old 09-27-2008, 10:24   #13 (permalink)
Member: 750874
Thanks Meter: 20
Nokia 3230 lcd white call incoming & outgoing ok, lcd bord ok,lcd ok,change lcd ic also no result what i do now?
Old 09-27-2008, 12:02   #14 (permalink)
Member: 646692
Thanks Meter: 4
good bro............good
Old 09-27-2008, 13:12   #15 (permalink)
howell's Avatar
Member: 697643
Thanks Meter: 68
this is nice thanks sir very usefull post..
nokia 3230 display problem shammysaini Nokia Hardware & Hardware Repair 3 06-09-2009 07:44
nokia 3230 display blank vimochan80 Nokia Hardware & Hardware Repair 3 11-30-2008 15:49
nokia 3230 displaying problem de brain box Nokia Hardware & Hardware Repair 1 09-04-2008 20:18
Nokia 3230 Display Problem stiffknot Nokia Hardware & Hardware Repair 7 06-21-2008 05:08
nokia 3230 display blinks every 5 6 seconds raj_cxe WD2 & APE (Symbian Phones) 13 02-16-2007 19:05
Page generated in 0.22311 seconds with 10 queries
