07-03-2008, 15:40 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: P A K I S T A N
Member: 805902 Status: Offline Thanks Meter: 31 | nokia 3230 white display have nokia 3230 problem with white display i have change display ic panel lcd n also chck lcd connector points but problem is not solved any one have solution |
07-03-2008, 17:01 | #3 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: bahrain
Member: 734871 Status: Offline Thanks Meter: 1,348 | Quote:
2. Its only light and turn off after fue seconds, check zocus. | |
The Following User Says Thank You to pupaji For This Useful Post: |
07-03-2008, 17:09 | #4 (permalink) |
Freak Poster Join Date: Jun 2008 Location: Heaven
Member: 801083 Status: Offline Thanks Meter: 99 | 3230 white display It,s white display but phone can receive call, or white display but can,t operate ? Solution White display but pnone can receive call : 1. Check ur LCD ( replace or change) 2. Check ur LCD conector on uper board (resolder or change) 3. Check ur line LCD conector to flexible if track cut --jumper 4. Check ur flexible --- change ur flexible 5. Check all conector in ur board --- clean, relace or change 6. check track from conector to Display IC --if cut ---jumper 7. Reball or change ur Display conector. 8. Finish check lines from display conector to UPP if cut -- reheat upp very ver ... carefulllly good luck |
07-04-2008, 10:36 | #5 (permalink) |
Member: 805902 Status: Offline Thanks Meter: 31 | thnx ADICKASIA iil try ur no 8/ solution n fone is working well.. thnx once again... |
The Following User Says Thank You to cellsolutions1 For This Useful Post: |
07-04-2008, 17:03 | #6 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: pakistan Age: 71
Member: 241039 Status: Offline Thanks Meter: 4,170 | Quote:
Rashid Ahmed Nadeem | |
The Following User Says Thank You to r a nadeem For This Useful Post: |
nokia 3230 white display | Gautam Mhz | Nokia Hardware & Hardware Repair | 3 | 09-12-2009 09:31 |
3230 white display | pratik_1111 | Nokia Hardware & Hardware Repair | 11 | 05-02-2008 22:32 |
3230 white display only plz help | amanhalwara | Nokia Hardware & Hardware Repair | 16 | 04-21-2008 12:41 |
Nokia 3230 White Display Only Rest Is Ok | rajus | Nokia Hardware & Hardware Repair | 5 | 04-01-2007 20:33 |
3230 white display plzz argent | ahmed89 | Nokia Hardware & Hardware Repair | 3 | 01-17-2007 22:19 |
