02-17-2002, 00:12 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | Nokia 3310 _KEY#1 any solution? |
02-19-2002, 11:48 | #3 (permalink) |
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | thanks about help,<br />i know what u mean most pcb's are 1,4,7 <br />but this one is different , i mean: + of 1,0,9,6 are same on this kind of boards?<br />i checked it on my unit, all are ok,<br />but when i connect wire from 1 to 2<br />then the key #1 is working well, <br />but key# 9 typing 7 and key #6 is typing 4 any help? |
02-20-2002, 11:30 | #6 (permalink) |
Freak Poster Join Date: Dec 1999 Location: Earth
Member: 751 Status: Offline Thanks Meter: 19 | @ARC Does the phone haven't been downgraded to a much lower version? I encountered this once before when I'm experimenting with different MCU versions on a 3310 I'm working with. BR, neb |
02-24-2002, 03:25 | #8 (permalink) |
Freak Poster Join Date: Feb 2002 Location: www.gsm-support.co.uk Age: 53
Member: 9302 Status: Offline Thanks Meter: 1 | All the keys are connected on the matrix.<br />Just follow the key one path ways it can be simple connection problem.<br />If not do not forget that UI chip is responsible for the lights, vibration and keypad.<br />Try to replace it with hot air. |
02-24-2002, 07:59 | #9 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Mauritius
Member: 5585 Status: Offline Thanks Meter: 8 | Hi, I encountered this problem once when I downgraded one 4.45 version to 3.24 and when I upgrade it back to 4.45, it works again. I had also tried other versions such as 4.35 and the problem remains.I think that you must try to upgrade it back to the original version. Regards Laval |
02-24-2002, 08:09 | #10 (permalink) |
Member: 5585 Status: Offline Thanks Meter: 8 | I also noticed that this problem I got it only in a batch of phone manufactured around july 01, you can check it by *#92702689# .Upgrade the phone to its original version it will work 100%. Regards Laval |
02-24-2002, 21:18 | #11 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | it s soft ware problem down grade the phone to 4.35 it s the only ver.. telefort soft ware ...<br />so the problem will fade away.. <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> |
Is it the on/off switch is same in between nokia 6600 and nokia 3310 | yccomc | Nokia Hardware & Hardware Repair | 2 | 09-30-2005 03:33 |
Wanted x1 nokia 3310 board & x1 nokia 3410 board | cameraman | Wanted Products | 4 | 09-12-2004 16:11 |
NOKIA 3310 | AMTX99 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-26-2001 17:01 |
There it is ! The new Nokia 3310 | Tevoxx | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-01-2000 13:44 |
NOKIA 3310 | Tevoxx | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 08-31-2000 14:05 |
