Old 08-18-2003, 16:12   #1 (permalink)
Member: 31534
Thanks Meter: 3
I m in a crasy problem
HI all guys,
I have NOKIA 3310, that's mic was not working. Therefore i rehot the cobba, but when i rehot the cobba the signals are disappear. secondly, i rehot again the cobba and the flash and also ram during in this working the hot is reached into the mad and some balls are out of the circles under the PCB board. Then i pressed power on but the power does not on. In this situation what do i do? But plz tell me the easy solution for this.
Thanks of all
bye...;
Old 08-18-2003, 16:23   #2 (permalink)
MPhoneClinic's Avatar
Member: 20639
Thanks Meter: 233
ohhh.... not really much solution here can help u.. diffenately have to replace CPU,,.. i have done them, but the PCB of the 33xx are sensitive, bcos of the glue underfill will grap the cicuirt lines as well, some are ok to replaced...
in your case, fingers crose and good luck
regards
TMPC
Old 08-18-2003, 16:26   #3 (permalink)
Member: 20639
Thanks Meter: 233
ohh be the way, if mic don't work, check the caps just above right hand top conner of cobba ( if not cobba fault), check the service manual to see which cap for mic.. sorry i don't remember the part number..
cheer
Samsung Z630 unlock problem = 2 in 1 cable problem or.. radez Z3X-Team Products 10 08-27-2008 22:19
Alcatel 7 in 1 cable problem cybercom BF, BG, TH, BHx Series 2 09-26-2004 10:29
loudspeaker in gd 68 problem digitalmk Panasonic 0 02-11-2004 21:05
8210 ... in "message menu" problem s4sajii Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 03-07-2002 09:38
Page generated in 0.12737 seconds with 9 queries
