07-05-2003, 21:09 | #1 (permalink) |
Junior Member Join Date: Apr 2003 Location: manila Age: 49
Member: 26035 Status: Offline Thanks Meter: 0 | Removing UEM I like to remove the UEM but i can't i heat it by the hot air but no way ,,,is there any Procedure or way to remove it please help me |
07-06-2003, 09:36 | #3 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Hong Kong. Age: 47
Member: 19979 Status: Offline Thanks Meter: 116 | in only 8310/6510 and a few other models u have UEM without glue..rest have glue around them so forget them but the ones without glue u can remove by using a hot air gun like the ones from Steinel or black&decker... WBR Syed |
07-06-2003, 16:09 | #6 (permalink) |
No Life Poster Join Date: Sep 2001 Location: Country of "TIHS"
Member: 6349 Status: Offline Thanks Meter: 6 | yeah...GSMWOlf...right.. We all can open it..although with Glue..., Rehot it (in 30-60Second) ,the LEAD/TIN will push out....after that pull the small hole with tweezers or any tool usually u use (place of Lead or TIN push out) , pull with very very carefully....if u pull with suddenly...it will broke the line of pcb under the IC,,ofcousre with hot air also still in position in the up of IC. Try it with carefully.... If u want to try... try it first with obsolete PCB...IC with glue.... |
07-06-2003, 22:16 | #10 (permalink) | |
Freak Poster Join Date: Feb 2001 Location: K.S.A Age: 23
Member: 3463 Status: Offline Thanks Meter: 4 | Quote:
thaaaanx man............it is work i tested | |
07-07-2003, 14:36 | #14 (permalink) |
Junior Member Join Date: May 2003 Location: Sussex Age: 66
Member: 28964 Status: Offline Thanks Meter: 0 | After replacing the UEM and before updating the Imei you should at least see text on the screen ie "test mode" etc. If you cannot and you believe the rest of the phone is ok then the UEM you have fitted is faulty (there are many faulty/bad UEM's). Or you have not fitted the UEM correctly and could have gicven the IC too much heat. Be careful of bad IC's this seems to be the most common reason in my area for UEM's not working. I have seen many UEM sealed as brand new in packaging yet they have a high failure rate. Some I have seen have only one IC in 6 that works. |
07-07-2003, 17:38 | #15 (permalink) |
Member: 6349 Status: Offline Thanks Meter: 6 | Best way to soldering BGA in PCB. This way i usually use to place new one Sensitive BGA IC: 1:Give Flux on PCB and under BGA IC, 2:Put BGA ic in right position...,after that.... 3:Rehot PCB under BGA around 15-40 second,with seting in Hot air around 280-310 degree (distance 2-3cm from PCB),till we see little smoke of flux ,sample:if we want place new one cobba in 3310..rehot with hot air firstly in under cobba pcb,i mean "LCD Side" right under cobba around 15-40 second. 4:After that..quiclkly move the Hot Air to up or on top of BGA IC...,in 5-10second BGA BALL will quickly be liquid to PCB. I use it in many2x BGA in case very Sensitive like CPU X35 , COBBA and etc.. Try it.,... I hope it will help for replacing Sensitive Cobba. |
After removal of glued UEM and glued uem removal video guide | Raheeeeb | Nokia Repair Guide and FAQ | 254 | 06-19-2019 01:40 |
want to change IMEI by REMOVING UEM | guruge06 | Nokia Hardware & Hardware Repair | 9 | 01-15-2009 17:22 |
Removing UEM using Heat Gun | rj4eva | Nokia Hardware & Hardware Repair | 14 | 12-06-2003 06:36 |
how to remove UEM | ayaz | Nokia Hardware & Hardware Repair | 8 | 05-31-2003 12:52 |
