06-03-2004, 14:38 | #1 (permalink) |
No Life Poster Join Date: Nov 2001 Location: Slovakia
Member: 7586 Status: Offline Thanks Meter: 11 | 6610 freezing 6610 freezing after few seconds after power up. on selftest gives this error : No signal - ST_IR_LOOP_TEST does any1 knows what should be the problem please? i will also welcome if any1 has descriptions of all tests in SELFTEST. b.r. Pali |
06-12-2004, 19:15 | #2 (permalink) | |
No Life Poster Join Date: Mar 2004 Age: 67
Member: 58052 Status: Offline Thanks Meter: 21 | Quote:
06-23-2004, 06:40 | #4 (permalink) |
Junior Member Join Date: Jun 2004 Location: philippines Age: 42
Member: 69056 Status: Offline Thanks Meter: 0 | hav you tried to restore factory dfaults after flashing? try to format the user area also maybe your 6610 has ran out of memery or memory low... tryto change flash ic... |
06-23-2004, 08:49 | #5 (permalink) |
Member: 7586 Status: Offline Thanks Meter: 11 | ram ic changed, flash ic changed , uem changed, flash new version, fact. default. When i power on the phone with sim card and leave it in ENTER PIN msg , phone is powered on more then 2minutes(i test just 2 minutes, maybe it will be longer) but when i enter pin, after few seconds it will freeze then power off. But when i make call after entering pin and logging to network i can call . I tried 2minutes call , then when i end call phone will freeze and then power off. Pali |
Samsung C5510 phone freeze | quayson81 | Z3X-Team Products | 1 | 03-30-2010 12:58 |
P910 phone freeze how un-freeze whith ns-pro? | .:Ripgsm:. | QUALCOMM Models (3G) | 0 | 01-11-2010 10:41 |
ZV40 phone FREEZE, i can make unlock but phone still freeze, how to fix it ? | PSG | UST Pro II | 1 | 10-19-2006 20:31 |
saya mencari pm 6610./i find pm 6610 | masirfan | Griffin | 1 | 08-29-2004 17:29 |
6610 Rom3 All locks CLOSED. HELP!!! | Max468 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 06-12-2002 22:05 |
