11-18-2010, 11:17 | #1 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 689645 Status: Offline Thanks Meter: 14 | nokia 5130 sort part is near battery conector |
11-18-2010, 14:44 | #4 (permalink) |
Member: 689645 Status: Offline Thanks Meter: 14 | i gote error fail to uplode image when i try to it with many format what is problem. saw image on this url http://*******.com/forums/attachment...0&d=1289828327 |
11-18-2010, 15:44 | #5 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | upload on ImageShack® - Online Media Hosting |
11-20-2010, 08:03 | #11 (permalink) | |
No Life Poster Join Date: Mar 2009
Member: 998084 Status: Offline Sonork: 100.1652656 Thanks Meter: 265 | Quote:
1..Remove this coil mark in (1)..if u want to check the light ic N2301 is short.... 2..Remove N3200 ic mark in (2) ...this is memory card driver ic .remove it to check shoting is gone or not.... 3..Remove this ic n6000 mark in (3)..this is blutooth & radio ic remove it to check shoting is gone or not because this ic also got +b volt from battery.... 4..Remove this ic n2100 mark in (4)..if u want to check the handfree ic because this ic also got +b volt from battery... 5..Remove this ic n1002 mark in (5)...if u want to check the pf N1002 this pf based on new tecknology... this this ic got +b from batery ic ... this ic work for network... 6..Remove ic N1001 mark in (6) ..if u want to check it ..this is rf ic based on new tecknology ...this ic got +b from batery ic ... this ic work for network... at end remove betty and avilma ic to check shoting is gone or not........ all the component which are mark in pink colur these all are coils and resistance these are place in series and +b of batery is gone throw them so if u remove the coil and resistance u not have to remove ic to check the shorting in pcb it save time and ur ic .... | |
The Following User Says Thank You to ..::akkas_sarkar::.. For This Useful Post: |
