01-30-2010, 16:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: USA Age: 35
Member: 530534 Status: Offline Thanks Meter: 41 | Nokia 5220 This phone have PM308 protected Any One Help me plx this is my Mxkey log Phone Type: RM-411 (Nokia 5220 XpressMusic) SW Version: V 05.63 12-01-09 RM-411 (c) Nokia Imei plain: 35684002394785-5 Product Code: 0563666 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2009-01-16T07:56:25Z SW Version: 05.63 Variant Version: 005 ProductProfile: RM411_0563666_05.63_005.spr Simlock: 0563666_simlock.bin Imei net: 356840023947855 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
01-30-2010, 16:48 | #2 (permalink) |
Product Manager Join Date: Oct 2007 Location: 乂事Lover事&
Member: 619738 Status: Offline Sonork: 100.1582811 Thanks Meter: 5,212 | First, did your phone from the beginning on the same situation or event that you |
The Following User Says Thank You to hamada-almasry For This Useful Post: |
01-30-2010, 17:26 | #6 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Unlock world
Member: 242469 Status: Offline Thanks Meter: 503 | SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! you can repair easy form with Mxkey ..... use repair sim lock function and write PM if is necesary ..... B.R |
This phone have PM308 protected, SD security in not restorable. | rashel.com | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 04-19-2010 15:30 |
Nokia N95 rm159 phone start-up failed contact the retailer [ Solved ] | mariaperezkkk | Cyclonebox | 19 | 03-30-2010 00:04 |
PM308 protected, SD security in not restorable I HAVE O/G BACKUP | kalpeshoza | Nokia Base Band 5 ( BB-5 ) | 8 | 01-28-2010 17:24 |
does this phone have SL3 security? | SLIPLOCK | Genie Universal | 14 | 11-19-2009 06:13 |
Compatible Nokia 5220 Dummy Phone | IPMART | ipmart WebShop | 0 | 10-25-2008 08:50 |
