Old 01-06-2010, 04:35   #1 (permalink)
Registered User
Member: 690799
Thanks Meter: 157
Nokia 3100/3120 "no network found" problem
Hi
I have 4 handset with me & all 4 has same problem "No network found" when manual search.
what i have tried is :
1. full erase
2. full flash
3. write pm
4. unlock
5. rehot PA,Uem,Upp.
Plz give me perfect soloution.
what need to change.
Thanks in advance.
Old 01-06-2010, 05:08   #2 (permalink)
naveedbutt's Avatar
Member: 1015336
Sonork: 100.1608410
Thanks Meter: 813
hi
its problom 150% hardvier rehot PA and change signal antina
good lock
The Following User Says Thank You to naveedbutt For This Useful Post:
Old 01-06-2010, 05:54   #3 (permalink)
paslang's Avatar
Member: 156088
Thanks Meter: 9
replace 2n2 capacitor....................
Old 04-10-2010, 07:53   #4 (permalink)
Member: 1153229
Thanks Meter: 4
wtf~~~~ no use
i cant make it solve
still the same problem
Old 04-10-2010, 08:17   #5 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
Originally Posted by nakshatra View Post
Hi
1. full erase
2. full flash
3. write pm
4. unlock
Thanks in advance.
only need reheat in flash chip............tested many times
Old 04-10-2010, 08:31   #6 (permalink)
sandeep barwal's Avatar
Member: 315138
Thanks Meter: 56
its hardware prob. sir first check signal in manual search if found and no acces then its pf prob.
if signal not found then this prob from rx ic,antina switch,duplexer ,or power ic .
check and reply
[email protected]
Nokia 6070 "no operator found" problem.Plz help.. jana1_2008 Nokia Hardware & Hardware Repair 8 10-06-2010 20:34
Nokia 6020 "No Network Found" Ankit Verma Nokia Hardware & Hardware Repair 8 03-14-2009 20:35
Nokia 6020 "No Network Found" Ankit Verma Nokia Hardware & Hardware Repair 13 10-08-2008 10:29
Nokia 6020 "No Network Found" Ankit Verma Nokia Hardware & Hardware Repair 1 03-16-2008 07:19
Nokia 8800 sirocco gold "no network found" taisfus Nokia Hardware & Hardware Repair 0 12-23-2007 05:53
Page generated in 0.14498 seconds with 9 queries
