Old 03-18-2008, 18:25   #1 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
nokia 5310, keypad 7. 8.9.problem.?
hi to @ all
i have a some piese 5310 key problem i use 7.8,9,key,outo,music one
whats problem and what can i do this job.. plz help
The Following 2 Users Say Thank You to gsm st For This Useful Post:
Old 03-18-2008, 21:39   #2 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
what u saying plz correct ur language
Old 03-18-2008, 21:42   #3 (permalink)
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
if u have problem in 7.8.9 botonns then change the keypad IC
Old 03-19-2008, 07:42   #4 (permalink)
gsm st's Avatar
Member: 143007
Thanks Meter: 141
sir boton is ok, i puse the key not sow 7.8.9. but play songs..
Old 03-19-2008, 08:05   #5 (permalink)
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
i can,t understand dear ..........................
Old 06-07-2008, 12:37   #6 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
Where is the ic keypad ? Is it near the clips of the keypad ? Please, thanks
Old 06-07-2008, 14:28   #7 (permalink)
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
Both Are Keypad Ic Near Keypad Connector
The Following 2 Users Say Thank You to makkah mobile For This Useful Post:
Old 06-07-2008, 18:14   #8 (permalink)
Registered User
Member: 362673
Thanks Meter: 37
I changed the two ic's three times but it's the same, 1 4 7 * call doesn't work.
The phone is water damaged.
B.R
Old 11-08-2008, 16:55   #9 (permalink)
Member: 582298
Post nokia 5310 ic
near nokia keypad cpnnector &this ic is 6300 display ic
Old 06-26-2009, 14:14   #10 (permalink)
Cheater -Don't Deal with him-
Member: 490708
Sonork: 100.1587135
Thanks Meter: 569
5310 kepaid 789 ples halp me.....................................
The Following User Says Thank You to mohsin10 For This Useful Post:
Old 06-26-2009, 14:30   #11 (permalink)
Member: 172343
Thanks Meter: 11
its simple man.........just open keypad and keypad base find the line and make jumper it will be ok....
Old 06-26-2009, 19:50   #12 (permalink)
chamak-liton's Avatar
Member: 735673
Thanks Meter: 3,101
keypad ic jumper it will be ok.try it
The Following User Says Thank You to chamak-liton For This Useful Post:
Old 06-26-2009, 20:20   #13 (permalink)
Member: 105817
Thanks Meter: 133
change keypak flex..
Old 06-26-2009, 20:47   #14 (permalink)
Member: 857458
Sonork: 222035
Thanks Meter: 24
5310 key pad sollution
try this way and reply me
Old 06-26-2009, 20:53   #15 (permalink)
Registered User
Member: 101744
Thanks Meter: 69
change keypad flex 100%
6210 keypad 7-8-9 not work smartpb Nokia Hardware & Hardware Repair 10 03-05-2013 21:11
Nokia 3250 Keypad 7,8,9 wsw243 Nokia Hardware & Hardware Repair 4 06-26-2010 12:54
D520 keypads 7,8,9, left, don't work, need help! vanhh Samsung Hardware Repair 1 08-20-2008 15:16
6600 keypad 7,8,9,number problem toolsveera Nokia Hardware & Hardware Repair 3 09-22-2007 23:52
C-25 keypad 7,8,9 not work tuppy Siemens Hardware Repair Area 0 12-03-2003 09:03
Page generated in 0.21935 seconds with 9 queries
