05-16-2008, 12:18 | #2 (permalink) |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | hint 1: check voltages inside pcb, you may find some voltage is low! this will indicates some problem in other part!, for ex., if you find a low voltage in vcore this means problem in CPU! hint 2 :try disconnect PA power supply, if problem solved then you need to change pa! Byte |
05-16-2008, 19:36 | #5 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | yes I think PA is faluty but check bat connector for shortge check short capasitors clean the pcb in u/s cleaner post result |
1600 no battery backup | richardjf77 | Nokia Hardware & Hardware Repair | 2 | 08-01-2009 07:06 |
C115 no battery backup | ..::ARUN::.. | Motorola Hardware Repair | 1 | 04-10-2009 14:14 |
Nokia 7610 No Battery backup? | .:MobileLife:. | Nokia Hardware & Hardware Repair | 6 | 09-23-2008 16:37 |
k310 no battery backup | j_prakashh | Sony Ericsson Hardware Repair | 1 | 08-20-2008 11:02 |
3220 No Battery Backup | sarojrkl | Nokia Hardware & Hardware Repair | 2 | 03-07-2007 13:15 |
