nokia 6300 orignal battrey not save help me i have nokia 6300 there is battrey not save any solution help me plz urgent |
1= change ur battery 2= change the charger if problem still not solved 3= simply reball thavo .. And ur problem will be solved tested....... |
6300 charging fault 2 Attachment(s) change charging ic tahvo. shown in picture red marked |
bro, put charger to the handset and check to the battery connector(without battery) how much volt output if out put is 3.7-4.00 volt, then change battery if output is not ok then you can change tahvo(at 1st try to rehot) best of luck post your result |
thavo work for me. thanks man. i changed and now charging |
