07-15-2004, 15:09 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: none Age: 49
Member: 11926 Status: Offline Thanks Meter: 0 | nokia 6310 strange signal problem *******r says it looses network, but it has full network Now I noticed, that when I close my hand near the antenna, it starts lossing network bars. Can someone help me repairing these phones ?? I changed Antena switch on one of them, but it didn't work out. Thks for all |
07-17-2004, 19:35 | #3 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | Hi guys I think it sounds like it might just be the external antenna connector that is at fault Also resolder the bga with mjoelner written on it It often gets dry joints then when giving phone a slight twist the signal drops away bar after bar I do not believe its a PA problem regards D. |
08-09-2004, 15:29 | #7 (permalink) |
Member: 11926 Status: Offline Thanks Meter: 0 | after changing the pa and antenna switch (from 6210), problem stills the same... it's very strange!!!! I heated mjoelner on one phone, to try if it could be its problem, but its in the same condition. |
08-17-2004, 00:09 | #9 (permalink) |
No Life Poster Join Date: Oct 2002 Location: PARIS
Member: 16856 Status: Offline Sonork: 1582037 Thanks Meter: 441 | As it was said try to solder external antenna connector or you can even short circuit it . It's rare fault but have you just checked with another antenna ? PS. If you've changed pa & antenna switch from 6210 , I don't think it's the same, plz confirm ! Max_B |
08-18-2004, 09:26 | #11 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Czech Rep. Age: 43
Member: 40423 Status: Offline Thanks Meter: 5 | 6310 and 6310i pa`s aren`t same. Be carful. (u can also use 3310 PA but u will lost 190mhz :O) ) check RX or TX problem. if phone has signal andu u can call from it RX is ok if not, find problem in PA, duplexer.... If u cant call on to phone its TX problem. than find problem in MJOELNER / HAGAR... Aloha |
10-15-2004, 14:45 | #12 (permalink) | |
Freak Poster Join Date: Jul 2003 Location: RS;Bosnia&Herzegovina Age: 50
Member: 33472 Status: Offline Thanks Meter: 17 | Quote:
E800 strange signal problem | jakrzys | Samsung Hardware Repair | 3 | 04-15-2007 08:18 |
3100 strange signal problem | armico596 | Nokia Hardware & Hardware Repair | 1 | 10-22-2006 11:49 |
6310i strange signal problem | gsm_style | Nokia Hardware & Hardware Repair | 5 | 10-13-2004 04:03 |
Nokia 3330 strange signal problem!!! | OncleOh | Nokia Hardware & Hardware Repair | 2 | 06-12-2004 22:54 |
3330 strange signal problem | VK | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 11-22-2002 23:49 |
