11-10-2009, 14:50 | #21 (permalink) | |
Junior Member Join Date: Apr 2008 Location: Cyprus
Member: 741104 Status: Offline Thanks Meter: 1 | Nokia 6500 slide memory card problem Quote:
Is worked for me.. THANKS on the back cover next to camera window is metal bit that stick out when you put the back cover on the phone it pushes the contact in between the camera and memory door which let the phone read the memory card. | |
The Following User Says Thank You to happylogos For This Useful Post: |
11-21-2009, 09:10 | #25 (permalink) |
Member: 747542 Status: Offline Sonork: ilhanrnm Thanks Meter: 2 | hi friend i read your mesagges on forum... can you help me pls? I hve 6500 S and when i plug the memory card telephone slowly and frezed and sometimes i cant see the memory card telephone always slowly with memory card but when i plug the memory card everythings is normal what is my problem? i did flash resolder and i changed memory cards and still same problems.. plz write me |
01-10-2010, 15:18 | #27 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: pakistan
Member: 652132 Status: Offline Thanks Meter: 146 | Quote:
all the solution given are good efforts, but before changing mmc ic you should confirm that the back cover of ur 6500s is ok , sometime this problem is due to bad contact of back cover , check the back cover of some other phone ur ph wiil b ok , then post | |
01-10-2010, 15:20 | #28 (permalink) | |
nokia 6500 slide is not showing memory card | shakil143 | Nokia Hardware & Hardware Repair | 3 | 01-08-2010 18:35 |
nokia n95 normal memory card problem | miya mollah | Nokia Base Band 5 ( BB-5 ) | 0 | 05-14-2009 11:01 |
NOKIA 7610 / 6670 Memory Card Probleme | suraj9860607689 | Nokia Hardware & Hardware Repair | 0 | 03-24-2009 06:58 |
...::: Nokia E70 Insert Memory Card Problem :::... | billal1050 | Nokia Hardware & Hardware Repair | 0 | 11-24-2008 10:23 |
