06-16-2007, 06:20 | #1 (permalink) |
No Life Poster Join Date: Mar 2007 Location: http://meo786.forumotion.com/ Age: 50
Member: 465162 Status: Offline Thanks Meter: 683 | Nokia 6600 KeyPad Solution i attached the picture of ic's, your can gues your problem, and work only related IC not both, because some time if you cann't identified your problem, it is very difficult to solve that prolems. When some keys of Nokia 6600 r not working and problem is in keypad ics then sometimes we have confused which ic we should replaced first .I’m giving some hints to make easy to diagnose which ic is faulty upper or lower. Upper ic = Connector Pin 1. Gnd 2. 3, 6, 9, # 3. 1, 4, 7, ABC 4. Call, 4, 5, 6 5. Clr, ABC,*, # 6. +v led 7. Right soft key 8. Menu, Left, Soft key 9. Joystick (Right) 10. Joystick (Left) Lower ic = Connector pin 11. Joystick (center) 12. Joystick (down) 13. Joystick (Up) 14. Left soft key, Right soft key 15. Gnd 16. 1,2,3,0 17. End call, 7, 8, 9 18. Menu 19. 2, 5, 8,* 20. Call, End call, Clr, 0 According to this if sometime few keys r not working in sequence then find in this chart. For example if 1,2,3,0 together r not working then we have to replace lower ic and if 1,4,7,ABC r not working then upper ic is faulty. |
The Following 7 Users Say Thank You to meo786pk For This Useful Post: |
06-16-2007, 06:37 | #3 (permalink) | |
Freak Poster Join Date: Jul 2006
Member: 311025 Status: Offline Sonork: 100.1607375 Thanks Meter: 171 | 6600 key Quote:
6600 100% ok | |
The Following 2 Users Say Thank You to sulai2k For This Useful Post: |
06-16-2007, 07:46 | #4 (permalink) |
Freak Poster Join Date: Sep 2005 Location: Qatar
Member: 180173 Status: Offline Thanks Meter: 28 | Great work.... it really helps us.... It makes the job easier.... And hoping that you could post same info on other models... If you hve ome please share it with us..... Keep it up man! |
06-16-2007, 23:44 | #5 (permalink) |
Junior Member Join Date: Aug 2006 Age: 47
Member: 340902 Status: Offline Thanks Meter: 1 | 6600 keypad ic my fault is with the lower ic it has been completley removed all that is left is the grid under i was told that it cannot be repaired as there is nothing to stick the ic to is this true can't get anyone in the uk to fix the phone help!! |
06-17-2007, 09:00 | #6 (permalink) |
Member: 180173 Status: Offline Thanks Meter: 28 | If all then its very hard to repair... u need to dig for the lines inside the pads removed... for you to do this u need microscope and a pointed knife... after u clean it u need to apply solder for the IC balls make contact on it.... |
06-19-2007, 10:06 | #10 (permalink) | |
Member: 180173 Status: Offline Thanks Meter: 28 | Quote:
just follow my instructions in the previous post... but be careful doing this... take your time... | |
Nokia N81 Keypad solution 100% Tested solution Here | gsmhosting | Nokia Hardware & Hardware Repair | 29 | 09-25-2012 09:11 |
Nokia 6600 keypad problem | vali.rusu | Nokia Hardware & Hardware Repair | 5 | 08-30-2010 23:34 |
6600 keypad solutions 100% | suresh_boy04 | Nokia Hardware & Hardware Repair | 10 | 08-15-2009 16:19 |
Nokia 6600 keypad Malfunction, Pls help!!! | kaino147 | Nokia Hardware & Hardware Repair | 7 | 10-10-2007 12:57 |
Nokia 6600 keypad prob. Both IC's replaced and keypad works for only few hours. HELP! | dizzu | Nokia Hardware & Hardware Repair | 4 | 10-17-2005 08:32 |
