03-09-2009, 12:40 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 771601 Status: Offline Thanks Meter: 10 | 1600 shorting problem???? how to solve? |
The Following User Says Thank You to sushilkumar For This Useful Post: |
03-09-2009, 13:58 | #2 (permalink) | |
No Life Poster Join Date: Mar 2009 Location: Basti, I N D I A Age: 34
Member: 988641 Status: Offline Sonork: sanjay chaudhary Thanks Meter: 342 | Quote:
R-22=70% cpu=30% injoy....... | |
03-10-2009, 14:28 | #4 (permalink) |
No Life Poster Join Date: Aug 2008 Location: india
Member: 843418 Status: Offline Thanks Meter: 740 | check shoting in nokia 1110,1110i,1112,1600,2610,2310,2626...... 1..remove this resistance mark in (1)..if u want to check the light ic is short....in some sets this resistance is not present ...so if it is not present then u have to remove light ic to check shoting is gone or not...... 2..remove resistance r2160 mark in (2)..if u want to check the shoting cause by n2160 (speaker ic).....because this ic also got +b from batery...... 3..remove ringer ic mark in (3)..if u want to check shoting remove it and check if shoting is gone replace it because ringer ic also got +b volt from battery.... 4..remove the pf ic n7700 mark in (4)...if u want to check this ic is short remove it and check shoting...if it is shot then replace it... 5..at end check the power ic d2200 mark in (4) and reemove it to check shoting is there or not...{be careful it is pasted}...... all the component which are mark in pink colur these all are coils these are place in series and +b of batery is gone throw them so if u remove the coil u not have to remove ic to check the shorting in pcb it save time and ur ic .... [email protected] |
i allways have this problem how to solve it | momayaz | Phoenix Black Box | 11 | 05-10-2005 18:16 |
C100........ "please wait" ... problem how to solve | PTR999 | VLSI, Conexant, Skyworks and Old Models | 28 | 12-30-2003 12:05 |
C100........ "please wait" ... problem how to solve | PTR999 | VLSI, Conexant, Skyworks and Old Models | 1 | 10-17-2003 06:21 |
