VLSI, Conexant, Skyworks and Old Models Old Models: SGH-600, SGH-2400, SGH-2200, SGH-2100, SGH-500, SGH-250, SGH-810, SGH-800. VLSI: A200, A208, A800, N100, N200, N288, N300, N400, N500, N600,N611, N620, N625, N628, R200, R201, R208, R210, R220,R225, T100, T108, T400, T408, T410, T500, T508. Conexant: A100, A110, A118, A300, A308, A400, A408 M100, T200, T208. Skyworks: A500, C100, C108, C110, P510, P518. |
10-16-2003, 09:45 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Fairyland
Member: 3383 Status: Offline Thanks Meter: 3 | C100........ "please wait" ... problem how to solve i have a samsung C100 always showing "please wait" every now n then , i tried e2p reset but doesnt help.... i dont have the flasher for this nd the flsh files , can someone tell me where to download this from ? any suggestions ???????? thanx |
10-16-2003, 20:51 | #2 (permalink) |
No Life Poster Join Date: Nov 2002 Location: D U B A I Age: 45
Member: 17651 Status: Offline Sonork: 100.81230 Thanks Meter: 318 | @PTR999 flash your phone with chines flash files.it will solve your problem. and you can get chines flash files in old posts. use search option. Thanks n Regards |
12-20-2003, 13:06 | #4 (permalink) |
No Life Poster Join Date: Jul 2002 Location: uk
Member: 13808 Status: Offline Thanks Meter: 163 | That error message is most likely hardware and has to do with the pocessor that needs rehoting...the processor contact to the board is probably bad,.... try that BR |
12-22-2003, 15:22 | #8 (permalink) | |
Member: 13808 Status: Offline Thanks Meter: 163 | Quote:
this is the solution..!!!! br | |
12-23-2003, 12:05 | #13 (permalink) |
No Life Poster Join Date: Mar 2002 Location: Karabakh - Azeris motherland Age: 45
Member: 9856 Status: Offline Thanks Meter: 2 | Well, it can be both processor and firmware problem seperately. Once, I had a phone with XEWF3 firmware. Phone had freezing and "Please Wait" problem. Did everything flashing/resetting/IMEI fixing etc. The problem remained. Just started to think of desoldering CPU, flashed it with AHWJ1 for operator WIND. The flash was one of the newest releases (October) and size of main flash is much bigger than that of XEWF3. Well, phone is working till now. Everything is OK! Like magic. What I want to say is, there is not standard solution for this problem. You should work with your hands and brain too, not only with your P4. Best Regards Sean Archer |
12-23-2003, 17:36 | #14 (permalink) | |
That you solved one isolated problem that does not mean others should be insulted....PLS GET THAT RIGHT INTO YOUR B***N br | |
12-24-2003, 02:19 | #15 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Viet Nam Age: 46
Member: 6881 Status: Offline Thanks Meter: 0 | You need goto http://www.gsmvietnam.com/support_ar...repair_e2p.zip and flash your phone |
W900i on "Plz Wait" Problem!!How to solve!! | MUNEEB_AKHTAR_RAZA | Cruiser Suite | 16 | 08-10-2006 03:30 |
Connection error problems - how to solve - PLEASE read here | zulea | Motorola P2K (USB-Smart) | 0 | 02-22-2006 15:29 |
i allways have this problem how to solve it | momayaz | Phoenix Black Box | 11 | 05-10-2005 18:16 |
C100........ "please wait" ... problem how to solve | PTR999 | VLSI, Conexant, Skyworks and Old Models | 1 | 10-17-2003 06:21 |
