01-30-2010, 09:04 | #1 (permalink) |
Freak Poster Join Date: Jun 2003 Age: 47
Member: 31604 Status: Offline Thanks Meter: 12 | Nokia 6700 key pad |
The Following 2 Users Say Thank You to sandy1276 For This Useful Post: |
02-15-2010, 18:29 | #4 (permalink) | |
Freak Poster Join Date: Jan 2009 Location: IN GSM WORLD Age: 45
Member: 959013 Status: Offline Thanks Meter: 262 | Quote:
brother flash with jaf ver 1.65 new ver on usb cable.you see after that problem 10000% solved.its tested by me 3-4 time. best of luck bye bahriphonewala | |
The Following User Says Thank You to BAHRI PhoneWala For This Useful Post: |
02-15-2010, 19:00 | #5 (permalink) |
No Life Poster Join Date: Jan 2008 Location: india Age: 36
Member: 690456 Status: Offline Sonork: 1587650 Thanks Meter: 117 | u change n1410(small black ic under the camera connector) post me rusult |
The Following User Says Thank You to askaralikp For This Useful Post: |
03-10-2010, 12:24 | #6 (permalink) |
Crazy Poster Join Date: Jan 2006 Location: Bulgaria
Member: 223629 Status: Offline Thanks Meter: 26 | like elx_06 says 1. remove camera flex and test the phone if works then problem is in it (already fixed 2 water damage phones like that) 2. if problem is camera flex remove camera gently with all block (green block cut the red dots gently) from metal case dont pull only camera becouse u can broke it) 3. clean all board + camera connectors under it and test again. good luck in my case it helped |
The Following 15 Users Say Thank You to mazymind For This Useful Post: |
04-03-2012, 05:44 | #14 (permalink) | |
Insane Poster Join Date: Mar 2009 Location: philippines
Member: 991791 Status: Offline Thanks Meter: 15 | Quote:
Nokia 6030 key pad problem | moienshah | Nokia Hardware & Hardware Repair | 1 | 07-30-2006 14:06 |
Nokia 6600 key pad and unlock code problem | awaismqsd | Nokia Hardware & Hardware Repair | 1 | 06-12-2006 16:13 |
nokia 3220 key pad problem | armico596 | Nokia Hardware & Hardware Repair | 4 | 06-08-2006 00:38 |
nokia 8310 key pad solution plz post here.. | faisi | Nokia Hardware & Hardware Repair | 0 | 11-01-2005 10:35 |
Nokia 6600 key pad problem | jay8ers | Nokia Hardware & Hardware Repair | 4 | 11-22-2004 19:30 |
