04-30-2013, 15:26 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: jamnagar
Member: 321534 Status: Offline Thanks Meter: 18 | nokia 7210c: contact service problem.. pass=293xjp |
05-01-2013, 06:17 | #3 (permalink) |
Member: 321534 Status: Offline Thanks Meter: 18 | Phone type: RM-436 (Nokia 7210 Supernova) SW version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35318003890899-5 Product code: 0566806 Battery voltage: 5201 mV, current: 16 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NIMMIIIIRRFF094B2F01, ver: 002.010 SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! Phone Type: RM-436 SW version: V 07.23 17-07-09 RM-436 (c) Nokia ID Test name Startup Result 3 EAR_DATA_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 15 SLEEP_X_LOOP Y passed 46 UEM_CBUS_IF Y passed 7 KEYBOARD_STUCK N passed 22 CAMERA_IF N passed 20 BACKUP_BATT N passed 43 LCD N passed 21 LPRF_IF N passed 44 LPRF_AUDIO_LINES N passed 2 CURRENT_CONS N passed 42 RADIO N passed 69 BACKLIGHT Y passed 33 SIM_LOCK N !failed ! 93 SECURITY N !failed ! 71 BT_WAKEUP N passed 96 HOOKINT N passed 88 TAHVOINT Y passed 101 BTEMP N passed 119 IIC N passed 108 EXT_DEVICE N passed 56 CDSP_SLEEPCLK_FREQ N passed 128 CDSP_SLEEPCLOCK_FREQ N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 81 CDSP_RX_IQ_LOOP_BACK N passed 77 CDSP_GSM_TX_POWER N passed |
05-01-2013, 07:12 | #4 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | here is the problem repair simlock with atf or mxkey for security failed write pm Quote:
05-01-2013, 07:17 | #5 (permalink) | |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Quote:
05-01-2013, 08:44 | #8 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | 33 SIM_LOCK N !failed ! 93 SECURITY N !failed ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! maxkey ATF infinty best and many other tool can fix fast and easy |
05-01-2013, 10:44 | #11 (permalink) | |
bro , its ot software problem ,its hadware problem and sim lock invalid means cpu damage. you will have 2 change combo ic.sure | |
05-01-2013, 10:55 | #12 (permalink) |
Member: 321534 Status: Offline Thanks Meter: 18 | (bro , its ot software problem ,its hadware problem and sim lock invalid means cpu damage. you will have 2 change combo ic.sure) i agree with u ,but when it come to me that time only simlock test fail but security is ok,after that i try to solve it and then simlock and security both test fail comming |
05-01-2013, 11:04 | #13 (permalink) |
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | First time when you try to repair simlock invalid problem it will give other problem security test faild. It is common problem. First repair sd andafter it write pm. Security test will be okk but simlock remain invalid. you will have to change cpu and flash from other 7210 set . This is final solution t repair sim lock invalid problem. |
05-01-2013, 11:42 | #14 (permalink) | |
Member: 321534 Status: Offline Thanks Meter: 18 | Quote:
ok....................boss | |
