10-03-2006, 18:36 | #1 (permalink) |
Major Poster Join Date: Jun 2006
Member: 299602 Status: Offline Thanks Meter: 8 | Nokia 7650 powering up problem. I wonder if anyone can help with a little problem I have with a Nokia 7650. When it is powered up it is 100% perfect everything works, but when you turn it off the fun begins, Nothing happens, press the on/off button and the set just lays there dead, no response from charging either. leave the phone for awhile and then it powers up and works fine!... possest? ok, obvious things like battery, switch and flexi cable seem ok, can anyone Help...please.......... Chris Last edited by hi_chris; 10-04-2006 at 14:10. |
10-05-2006, 17:34 | #3 (permalink) |
Member: 299602 Status: Offline Thanks Meter: 8 | Just changed cable with a known good cabel, still the same. once the phone powers up it is fine no prpblems atall, guess I just will have to leave it turned on! Thanks any way Chris |
10-08-2006, 06:12 | #5 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 223959 Status: Offline Thanks Meter: 8 | yes the problem is with flex cable once there was 7650 with but in that there was a network problem i tried everything to repair network but didnt found any success somebody told me to change the cable in this forum i changed it & the network was succesfully repaired i m sure in ur case also there is a problem of cable |
11-08-2006, 21:06 | #7 (permalink) | |
Freak Poster Join Date: Mar 2006 Location: Portugal Age: 41
Member: 241933 Status: Offline Thanks Meter: 77 | Quote:
Hi 2 all I have the same problem with nokia 7650.... i have changed the flex cable to pad and no result........ anyone have more ideas | |
7650 power up | sirharlequin | WD2 & APE (Symbian Phones) | 3 | 08-14-2003 18:14 |
T20e power up problem | legija | Sony Ericsson Hardware Repair | 2 | 09-02-2002 21:34 |
Gd 92 power up problem | GSM RAJ | Panasonic | 0 | 07-28-2002 12:55 |
flash power up problem | kage | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-04-2002 17:51 |
Trium Mars K08 Power up Problem! | valdeira | Mitsubishi | 1 | 10-07-2001 21:03 |
