Old 10-09-2012, 04:19   #1 (permalink)
niaz muhammad's Avatar
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
x2-02 problime???
x2-02 after flash ok but after one or tow time on in same problime then softwear corupt plz help me thanksssss in advance
The Following User Says Thank You to niaz muhammad For This Useful Post:
Old 10-09-2012, 04:24   #2 (permalink)
sami ullahkhan's Avatar
Member: 1780311
Sonork: 100.1615434
Thanks Meter: 124
download latest Flash file.........version11.79
The Following User Says Thank You to sami ullahkhan For This Useful Post:
Old 10-09-2012, 04:31   #3 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
i use letest ver but same problime.............. ver 11.79
Old 10-09-2012, 04:43   #4 (permalink)
aliyousafzai's Avatar
Member: 1358184
Sonork: 100.1616912
Thanks Meter: 615
what condition before flashing?
The Following 2 Users Say Thank You to aliyousafzai For This Useful Post:
Old 10-09-2012, 09:00   #5 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
normal
The Following 2 Users Say Thank You to niaz muhammad For This Useful Post:
Old 10-09-2012, 09:04   #6 (permalink)
Member: 515669
Sonork: +84977190719
Thanks Meter: 7
run software. chạy phần mềm
Old 10-09-2012, 09:26   #7 (permalink)
Member: 1358184
Sonork: 100.1616912
Thanks Meter: 615
if condition was normal before s/w then why you flashed? for what problem?
Old 10-09-2012, 12:06   #8 (permalink)
Member: 1573546
Thanks Meter: 21
What is wrong with the device does not give him should
The Following User Says Thank You to a012210ah For This Useful Post:
Old 10-13-2012, 03:47   #9 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
my problime is same phone is off or full flash ok but after two or there time on same problime phone is off only light shwo then off
Old 10-13-2012, 04:35   #10 (permalink)
Member: 454358
Thanks Meter: 11
show phone info log plz..
The Following User Says Thank You to CiptaCom For This Useful Post:
Old 10-13-2012, 14:24   #11 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
this is log
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0854F9A
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 01006465
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: nmwcdc, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version: Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35243005675224
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35243005675224_ back.RPL)
Processing file: rm694__11.84.mcusw
Downloading item CODE:rm694__11.84.mcusw_ebl_psi.fls, num block: 4, size: 26.25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.359 s
Erasing area 0x40040000-0x4005FFFE ...OK
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.500 s
Erasing area 0x40280000-0x41B7FFFE ...OK
Programming completed in 36.297 s
Checksum verified (0xB615)
Processing file: rm694__11.84.ppm_m_a
Downloading item CUSTackage_m_a.ppm_ebl_psi.fls, num block: 1, size: 4.25 MB
Erasing area 0x41C00000-0x4204033E ...OK
Programming completed in 6.687 s
Checksum verified (0x40FC)
Processing file: rm694__11.84.image_m_a_059J701
Downloading item CUSTackage_m_a_059J701.image.fls, num block: 1, size: 13.75 MB
Erasing area 0x42300000-0x43E1FFFE ...OK
Programming completed in 22.141 s
Checksum verified (0x1F44)
Total time for flashing process(boot+erase+write) was 9 min 17.672 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 627ACFB
Verifying communication to device OK.
Phone type: RM-694 (X2-02)
SW version: V 11.84 13-09-12 RM-694 (c) Nokia
Imei plain: 35243005675224-2
Product code: 059D1V1
Language Pack:
- not available.
Imei net: 35243005675224
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 10-15-2012, 05:19   #12 (permalink)
Member: 1519396
Sonork: 100.1612702
Thanks Meter: 1,951
plz help me same problime
Old 10-15-2012, 05:47   #13 (permalink)
Registered User
Member: 1437921
Sonork: 100.1668345
Thanks Meter: 13
Thumbs up use infinte best dongal porblam solved 100%
Page generated in 0.19270 seconds with 8 queries
