03-25-2011, 16:54 | #1 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Baroda Age: 42
Member: 5871 Status: Offline Thanks Meter: 87 | Nokia C3-01 Display Problem Solution:- Hints in troubleshooting Nokia C3-01 Display problem: 1. Try to replace the LCD screen module. 2. Try to restore, flash update the phones firmware. Its RM 640 for C3-01 and RM 662 for C3-01m 3. Check/clean the LCD pin connector. 4. Check read the VAUX 2.78V and VIO 1.8V, and the components like the capacitor and filter coil on it. 5. Replace the EMI/ESD filter IC's, Nokia C3-01 LCD Screen Display backlight LED Problem Solution Check/ replace the highlighted components such as the filter coil, diode and transistors. Check the battery VBAT voltage 3.7V across the inductor coil. Nokia C3-01 Charger No Response- Not Charging Problem Solution Repair hints for Nokia C3-01 Not Charging Problem: 1. Check and replace the battery Charger. 2. Check and replace the phone's battery. A fully drained battery won't charge up. 3. Check/clean or replace the charging DC jack connector and the PCB pads. 4. Check/replace the fuse, diode and coil. 5. Trace the charging voltage line paths from the V+ terminal pads or the coil down to the capacitor near the PEARL IC. If the above procedures won't work, the possible faulty is the Pearl IC, reheat or reworking it might only fix the problem. Last edited by Winner58; 04-02-2011 at 10:29. |
The Following 6 Users Say Thank You to kulu For This Useful Post: |
04-01-2011, 08:38 | #2 (permalink) |
Member: 5871 Status: Offline Thanks Meter: 87 | Earpiece Speaker Problem Solution ALL THE GSM SOLUTIONS: Earpiece Speaker Problem Solution Nokia C3-01 solution for keypad filter IC ALL THE GSM SOLUTIONS: Nokia C3-01 solution for keypad filter IC Nokia C3-01 keypad light problem ALL THE GSM SOLUTIONS: Nokia C3-01 keypad light problem Nokia C3-01,C3-01m Memory card flex cable jumper ways ALL THE GSM SOLUTIONS: Nokia C3-01,C3-01m Memory card flex cable jumper ways Nokia C3-01,C3-01m Insert Sim Card problem, Flex Jumper Ways Solution ALL THE GSM SOLUTIONS: Nokia C3-01,C3-01m Insert Sim Card problem, Flex Jumper Ways Solution Last edited by Winner58; 04-02-2011 at 10:29. |
The Following User Says Thank You to kulu For This Useful Post: |
05-25-2011, 17:31 | #3 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1498696 Status: Offline Thanks Meter: 0 | pls help c3 light 2 [email protected] x3 network diagram |
05-25-2011, 20:11 | #4 (permalink) | |
Freak Poster Join Date: Mar 2011 Age: 41
Member: 1542608 Status: Offline Thanks Meter: 94 | Quote:
chak here c3 light http://forum.gsmhosting.com/vbb/f148...1/#post7248488 | |
09-23-2011, 19:09 | #6 (permalink) |
Insane Poster Join Date: Nov 2008
Member: 895943 Status: Offline Sonork: zimonjic Thanks Meter: 15 | C3 Lcd Light 100% tested this is url , tested juper solutio phone was water dameged this is url http://imageshack.us/photo/my-images/43/c3lcdlight.jpg/ Last edited by samkozi; 09-23-2011 at 19:15. |
12-06-2012, 13:13 | #10 (permalink) |
Crazy Poster Join Date: Aug 2007 Location: Baguio
Member: 559572 Status: Offline Thanks Meter: 6 | on this jumpers on filters ic is definitely difficult, as it is very small and you should have good soldering iron... why you will do the hard way??? just change same filter ics will be ok as I did... it works 100%. if you like to order ic,s just PM me here in Dubai... delivery will be maximum 3 weeks... |
02-18-2014, 12:58 | #11 (permalink) |
Junior Member Join Date: May 2006
Member: 284806 Status: Offline Thanks Meter: 0 | I have c3-01. my phone camera led always lighting. i am looking on board camera led driver(regulator) n1400 broken. i dont have same motherboard. Please help same transistor what type is transistor n1400 ? or another phone board where is it. Thanks for help... |
