08-12-2011, 17:03 | #1 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1231949 Status: Offline Sonork: 12 Thanks Meter: 42 | Nokia c5-00 only vibrate, not turn on , and work 100% when connected with pc on usb I have a Nokia c5-00 rm-645 , it not turn on with battery, it turn on only with the USB cable attached to the pc, I changed the battery but the same problem I flashed it with his product code and 62.001 version but still the same problem when I attached to the pc with usb, it turn on normally but with battery , only vibrate here is a phone info and the self test is all 100% with ATF MCU Version: V ICPR82_10w34.4 09-12-10 RM-645 (c) Nokia IMEI Plain : 355970046527771 IMEI Spare : A355970046527770 IMEI SV : 33559700465277713F Phone Model: Nokia C5-00 Product Serial Number: 16BC889AA Product Code : 0593732 Module Code : 0204492 Basic Production Code: 0592655 Default SN Type : 0 PPM Version : V ICPR82_10w34.4 09-12-10 RM-645 (c) Nokia HW Version : 6502 RFIC Version : |Vapaus_6.5 | Mikki_1.1 DSP Version : ICPR82_10w34.3 AHNE Version : 11 APE SW Core Version : 062.001 APE Variant Version : 062.001062.001.10.01062.001.C00.01 APE Test Version : 10wk48v0.001_APEONLY Retu Version : 35 Tahvo Version : 00 APE HW Version : 256 APE ADSP SW Version : 256 ******** Reading SimLock ******** CONFIG KEY: 0000000000000000 PROVIDER KEY: 2440700000000000 Provider : AT&T;U.S.A. (3650) Counters : 0/3 , 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SP Lock Status : Not Locked SIMLOCK_TYPE : PA_SL3 (15-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : ENCRYPTED PHONE_MODE : LOCAL MODE please help me |
08-12-2011, 18:46 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Quote:
hope your problem will be solve. | |
05-21-2012, 18:25 | #10 (permalink) |
Freak Poster Join Date: Feb 2011 Location: karachi
Member: 1511448 Status: Offline Sonork: [email protected] Thanks Meter: 10 | plzzzzzz frndzzzzz upload any working solution |
07-17-2012, 18:23 | #11 (permalink) |
No Life Poster Join Date: Apr 2011 Location: kerala
Member: 1550704 Status: Offline Sonork: 100.1644808 Thanks Meter: 248 | 1 open the mx box tool 2 click to service tabe 3 click to quick fix 4 the click the last one is...... BB5RAp3NAND Erase user area 5 click to... Do selected Jobe |
07-23-2012, 13:44 | #12 (permalink) |
Freak Poster Join Date: Oct 2010 Location: jamnagar(gujarat)india Age: 33
Member: 1418631 Status: Offline Sonork: 100.1622972 Thanks Meter: 79 | MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: ******** Using device: HTI, FW ver: 00.50, SN: ******** Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 27700103909C03443BE99D49EB68C7DC69CB9C13 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Processing MCU file: rm645_071.005_prd.core.fpsx [BB5,XSR 1.6] size: 96.64 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 170.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 28.640 s Processing PPM file: rm645_071.005_21.01_India_prd.rofs2.fpsx [BB5,XSR 1.6] size: 27.64 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 51 MB CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 18.032 s Processing PPM file: rm645_071.005_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 8.01 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 14 MB CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 0.140 s Processing CNT file: RM645_ENO_10wk48v0.001.fpsx [BB5,XSR 1.6] size: 2.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS*ENO block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 6.375 s Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D] ...OK Erase size: 72 MB CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 4.765 s Total time for flashing process(boot+erase+write) was 6 min 8.250 s no local/test mode and no power on please help. |
The Following User Says Thank You to HBHAVNA For This Useful Post: |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
