Old 02-20-2010, 03:19   #1 (permalink)
Registered User
Member: 1098397
Thanks Meter: 80
nokia 3230 phone start-up failed help me
nokia 3230 phone start-up failed contact the retailer help me
The Following User Says Thank You to palav For This Useful Post:
Old 02-20-2010, 03:54   #2 (permalink)
Registered User
Member: 1098397
Thanks Meter: 80
chk
Getting MCU ID
MCU ID: 0x1081
FLASH ID0: 007E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 007E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 277E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
info
Powering the phone...
Reading...
MCU SW version: V 5.0614.0
22-03-06
RM-51
(c)NMP
HW version: 0580
PCI version:
UEM version: 144
UPP version: 4225
RFIC version: 0205
DSP version: B0439U_05w33
PPM version: V 5.0614.0
22-03-06
RM-51
(c)NMP.05
Production serial number: DNA032914
Product code: 0522253
Module code: 0202511
Basic production code: 0519957
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: h?????????????????????????????????????????????????
Default SN type: h?????????????????????????????????????????????????
IMEI plain: 357099002940535
IMEI spare to net: 3A 75 90 09 20 49 50 03
IMEI SV to net: 33 75 90 09 20 49 50 13 F2
PDC: 4E 54 54 4A 50 12 34 56
Master Code: 0157056376
Phone type: RM-51, Software version: 5.0614.0, Language Pack: 05
User code: 12345
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-51.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0522253
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-51\
Scanning for ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE506140.C1
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-51\RM51PE506140.33
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Done!
Old 02-20-2010, 03:59   #3 (permalink)
venuno's Avatar
Member: 532761
Sonork: 100-1592994
Thanks Meter: 1,104
try unlock first if same
erase flash
flash latest version if have
write pm
unlock
Old 02-20-2010, 04:57   #4 (permalink)
Member: 675717
Thanks Meter: 125
First hand format > Reheat ram > Change ram > Reheat flash ic.
Old 02-20-2010, 05:08   #5 (permalink)
Member: 1014826
Thanks Meter: 88
format with jaf or hwk working well>>>>>>>
Old 02-20-2010, 13:23   #6 (permalink)
Registered User
Member: 1098397
Thanks Meter: 80
erase flash
write pm
unlock
not work help me.......................................
Old 02-20-2010, 13:26   #7 (permalink)
Dhika's Avatar
Member: 629320
Thanks Meter: 47
just writ a good pm broo it slove
Old 02-20-2010, 13:34   #8 (permalink)
rockindheeraj's Avatar
Member: 1002000
Sonork: 100.1604575
Thanks Meter: 90
bro try to do format user area
best regards
rockindheeraj
Old 02-20-2010, 13:58   #9 (permalink)
klmamn's Avatar
Member: 986273
Thanks Meter: 397
chk
Getting MCU ID
MCU ID: 0x1081
Algo is ready...
Done!
Phone Restarted...
info
Reading...
22-03-06
RM-51
(c)NMP
HW version: 0580
PCI version:
UEM version: 144
UPP version: 4225
RFIC version: 0205
22-03-06
RM-51
(c)NMP.05
Flash code:
Order number:
Long production SN:
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
just formate user area by jaf whk or even by ur hands
all will b fine
The Following 2 Users Say Thank You to klmamn For This Useful Post:
Old 07-21-2011, 16:22   #10 (permalink)
tejas243404's Avatar
Member: 725038
Sonork: 100.1675584
Thanks Meter: 288
10000% working to *---3-- caling batan ,,--pawar on ok,,to
Old 08-28-2011, 10:34   #11 (permalink)
praji's Avatar
Member: 563648
Sonork: 100.1594523
Thanks Meter: 87
I did for 3230 "startup failed"
FORMAT USER AREA in UFS after UI SETTING
perfect working
try if manual format not working
3230 Phone Start up Fail Repaired By Typhoon Chennairam Typhoon Dongle 8 08-28-2011 16:23
n96 contact retailler-phone start up failed--help me for SX4 zone2 Nokia Base Band 5 ( BB-5 ) 11 05-11-2010 09:15
Nokia N96 phone start-up failed. help me rafiqcell Nokia Base Band 5 ( BB-5 ) 6 01-16-2010 06:38
nokia 7610 phone start-up failed help me pls palav Nokia Hardware & Hardware Repair 15 12-11-2009 07:58
N96 After unlock phone start up fail help me chamin Nokia Base Band 5 ( BB-5 ) 9 06-26-2009 12:30
Page generated in 0.27570 seconds with 9 queries
