Old 04-20-2008, 08:22   #1 (permalink)
Member: 743358
Sonork: dhie2424
Thanks Meter: 6
nokia6600 cannot power on when press switch
hi! can u help nokia6600 ok when charging theres a light and power, and when insert to UFS box it appears nokia and has power also...but when i switch it on cannot power on...what is the problem??? there is other solution to that problem can u give me a pics/procedure where can i jumpering...plsss...help...thanks a lot!!!
Old 04-20-2008, 09:11   #2 (permalink)
Member: 754725
Sonork: EXPERT00
Thanks Meter: 3
when charging d phone can on and chaging like normal .. izzit and tats mean d phone is ok . and when u put battery cannot on izzit ,, then u check d on/off got damage .. or change new one ,, or u solder d battery pin .. or u check vbat and bsi line to uem got damage or broken or not .. is so easy only mAN ..
KP501 switched on when press power to unlock Cake UST Pro II 1 02-18-2010 15:20
..::n70 not power on when press power button retu very hot::.. HUM Nokia Hardware & Hardware Repair 13 12-22-2009 11:40
nokia 6500s it comes on when charging but dose not power on when u press on 4 u man Nokia Hardware & Hardware Repair 3 04-06-2009 20:29
Cannot power on when cable connected bozzan S-Gold Based Phones 2 01-28-2006 11:42
be4 powers on when unlock is pressed shaider Alcatel & TCL Old Models 11 01-30-2002 01:45
Page generated in 0.14405 seconds with 9 queries
