09-21-2012, 05:09 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: india
Member: 1791098 Status: Offline Thanks Meter: 22 | nokia e63 rm-437 only vibrating Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.05, (Aug 22 2012 23:26:51, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0005A4A HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk44 Initializing security card... Card Serial Number: D00A00CB Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.16v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.12v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.15v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.928GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Pre flash tasks finished, continuing... Selecting USB Flashing Method... Proceeding with Dead USB Mode Press power-on shortly to run USB Boot ROM [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0FF00015949F005211F39ED8957901892FCFD1A8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: C70CB07324056BC66A824347F40DB2D5 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5 Sending RAW Loader... DeadUSB.alg, Type: Algorithm, Rev: , Algo: XSR 1.5 Sending CMT RAW Algorithm... [Nokia BB5 ADL Loader USB Generic]: Port opened OK! ADL Server Startup Confirmed OK! Processing rm437_510.21.010_prd.c00 (CMT)... rm437_510.21.010_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5 Partitioning... Partitioning OK Started flash erase EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00A00000-0x0759FFFF, ONENAND EraseArea[0,CMT]: 0x0F1C0000-0x0F8BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Erase taken 0.547s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS*CORE Certificate... Writing CMT SOS+ROFS Certificate... All blocks written OK! Time taken 83.547s Flashing Speed: 6368.63 kBit/S Processing rm437_510.21.010_prd.v27 (CMT)... rm437_510.21.010_prd.v27, Type: Flash Image, Algo: BB5, XSR 1.5 Started flash erase EraseArea[0,CMT]: 0x05420000-0x0759FFFF, ONENAND Erase Partition (CMT) Erase taken 0.141s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFX Certificate... All blocks written OK! Time taken 33.703s Flashing Speed: 5978.86 kBit/S Processing rm437_510.21.010.35U (CMT)... rm437_510.21.010.35U, Type: Flash Image, Algo: BB5, XSR 1.5 Started flash erase Erase Partition (CMT) Erase taken 0.0s Writing all blocks... Initializing TurboCache... TurboCache Loaded! All blocks written OK! Time taken 26.891s Flashing Speed: 6153.76 kBit/S Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx (CMT)... RM437_ENO_008.07.45_100.71.952.a018.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5 Started flash erase Erase Certificate: SOS*ENO (CMT) Erase taken 0.0s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... All blocks written OK! Time taken 2.94s Flashing Speed: 6156.53 kBit/S Processing sofie_erase_y_drive.fpsx (CMT)... Restarting CMT... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Phone not detected at USB -> Timeout, no any compatible USB device detected. display only blue light pleas help me sir |
11-17-2012, 10:29 | #4 (permalink) |
Freak Poster Join Date: Aug 2012 Location: jodhpur india Age: 41
Member: 1796401 Status: Offline Sonork: 100.1623409 Thanks Meter: 56 | nokia e63 rm-437 only vibrating Establishing Connection with Box in Main Mode... Handling device: [Cyclone Team], [Cyclone Bootloader], [Platform: Classic] Handling device: [Cyclone Team], [Cyclone Box], [Platform: Classic] Initializing box... Box Firmware: Cyclone Main Application v02.05, (Aug 22 2012 23:26:51, gcc v4.3.3, RTOS V6.0.1), Type: Signed Production Application, (C) KarwosSoft 2012 Hardware Platform: Cyclone Classic Flasher Interface (c) 2008,2009 KarwosLabs Box Serial Number: C0005A4A HW Revision: C, Suitable for: Production, Case: First Plastic Case, MCU Manufacture Time: 2010, wk44 Initializing security card... Card Serial Number: D00A00CB Card Firmware Revision: 010A Card is activated Box is activated Started box selftests procedure USB Voltage 5.16v PASSED MCU Voltage 3.29v PASSED Core Voltage 1.78v PASSED VBAT Voltage 0.01v PASSED VBAT Voltage 5.12v PASSED Box VPP disabled VPP Voltage 0.04v PASSED Internal Box VPP Enabled VPP Voltage 5.15v PASSED Box VPP disabled VPP Voltage 0.04v PASSED External Box VPP Enabled VPP Voltage 0.04v FAILED - IGNORED - Probably power supply is not connected Box VPP disabled All box selftests passed! Super DCT4 Activation: TRUE XGold/Blackberry Service Running, Counter: 100 Avaiable Physical Memory: 1.1023GB Avaiable Virtual Memory: 1.928GB Avaiable Pagefile: 3.1023GB Initializing FBUS... All initialized - Ready to work Processing pre flash tasks... Pre flash tasks finished, continuing... Selecting USB Flashing Method... Proceeding with Dead USB Mode Press power-on shortly to run USB Boot ROM [Nokia USB Flashing Generic]: Port opened OK! Old ROM Detected CMT_SYSTEM_ASIC_ID: 000000010000022600010006400C192101051103 CMT_EM_ASIC_ID: 00000296 CMT_EM_ASIC_ID: 00000B22 CMT_PUBLIC_ID: 0FF00015949F005211F39ED8957901892FCFD1A8 CMT_ASIC_MODE_ID: 00 CMT_ROOT_KEY_HASH: C70CB07324056BC66A824347F40DB2D5 CMT_BOOT_ROM_CRC: 4B9B7510 CMT_SECURE_ROM_CRC: 3E691FF8 DeadUSB.raw, Type: 2nd Boot Loader, Rev: , Algo: BB5 Sending RAW Loader... DeadUSB.alg, Type: Algorithm, Rev: , Algo: XSR 1.5 Sending CMT RAW Algorithm... [Nokia BB5 ADL Loader USB Generic]: Port opened OK! ADL Server Startup Confirmed OK! Processing rm437_510.21.010_prd.c00 (CMT)... rm437_510.21.010_prd.c00, Type: Flash Image, Algo: BB5, XSR 1.5 Partitioning... Partitioning OK Started flash erase EraseArea[0,CMT]: 0x00040000-0x007FFFFF, ONENAND EraseArea[0,CMT]: 0x00A00000-0x0759FFFF, ONENAND EraseArea[0,CMT]: 0x0F1C0000-0x0F8BFFFF, ONENAND Erase Partition (CMT) Erase Partition (CMT) Erase Partition (CMT) Erase taken 0.547s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT ADA Certificate... Writing CMT KEYS Certificate... Writing CMT PRIMAPP Certificate... Writing CMT RAP3NAND Certificate... Writing CMT PASUBTOC Certificate... WARNING: CMT PAPUBKEYS Hash is Empty, writing first found PAPUBKEYS Writing CMT PAPUBKEYS Certificate... Writing CMT SOS*UPDAPP Certificate... Writing CMT SOS*DSP0 Certificate... Writing CMT SOS*ISASW Certificate... Writing CMT SOS*CORE Certificate... Writing CMT SOS+ROFS Certificate... All blocks written OK! Time taken 83.547s Flashing Speed: 6368.63 kBit/S Processing rm437_510.21.010_prd.v27 (CMT)... rm437_510.21.010_prd.v27, Type: Flash Image, Algo: BB5, XSR 1.5 Started flash erase EraseArea[0,CMT]: 0x05420000-0x0759FFFF, ONENAND Erase Partition (CMT) Erase taken 0.141s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS+ROFX Certificate... All blocks written OK! Time taken 33.703s Flashing Speed: 5978.86 kBit/S Processing rm437_510.21.010.35U (CMT)... rm437_510.21.010.35U, Type: Flash Image, Algo: BB5, XSR 1.5 Started flash erase Erase Partition (CMT) Erase taken 0.0s Writing all blocks... Initializing TurboCache... TurboCache Loaded! All blocks written OK! Time taken 26.891s Flashing Speed: 6153.76 kBit/S Processing RM437_ENO_008.07.45_100.71.952.a018.fpsx (CMT)... RM437_ENO_008.07.45_100.71.952.a018.fpsx, Type: Flash Image, Algo: BB5, XSR 1.5 Started flash erase Erase Certificate: SOS*ENO (CMT) Erase taken 0.0s Writing all blocks... Initializing TurboCache... TurboCache Loaded! Writing CMT SOS*ENO Certificate... All blocks written OK! Time taken 2.94s Flashing Speed: 6156.53 kBit/S Processing sofie_erase_y_drive.fpsx (CMT)... Restarting CMT... All images processed OK! Processing post flash tasks... Setting Factory Defaults... Phone not detected at USB -> Timeout, no any compatible USB device detected. display only blue light bro. cheng betty ic and check |
11-17-2012, 12:16 | #5 (permalink) | |
No Life Poster Join Date: Nov 2010 Location: Searching....
Member: 1442705 Status: Offline Thanks Meter: 1,061 | bro... flash with blank ppm and post result............... Quote:
