Old 02-14-2010, 18:32   #1 (permalink)
Member: 669597
Nokia E71 keypad problem.. Buttons 3,6,9 and menu is not working
Need help badly, my nokia E71 is acting weird. Buttons 3 6 9 and menu button is not working. I am sure this is a not a new problem. I searched google and found that this happens to others too, bt no one has sol. GSM hosting is my last hope..
Old 09-10-2010, 09:26   #2 (permalink)
Crazy Poster
Member: 7187
Thanks Meter: 12
new result : vol keys , k , l . , , back key not works reheat / replace smaller ESD flter
The Following User Says Thank You to tzlc For This Useful Post:
Old 09-10-2010, 10:37   #3 (permalink)
papu3090's Avatar
Member: 852566
Thanks Meter: 464
chang keypad ic.....
The Following User Says Thank You to papu3090 For This Useful Post:
Old 09-10-2010, 11:40   #4 (permalink)
Member: 277937
Thanks Meter: 48
change flex broth not other so;v
Old 07-24-2012, 19:12   #5 (permalink)
Member: 220595
Thanks Meter: 355
I have a similar problem with one set which has been open several times, it looks like the keypad membrane has been damaged somewhere, it must be one or two broken tracks.
For my case replacing the keypad membrane/ flex is not a choice, so I need to repair this one with some jumper.
Anyone has a keypad schematic/ways ?
Old 05-12-2013, 13:49   #6 (permalink)
Member: 1797583
Sonork: 12345
Nokia E 71: Menu, 9, 6 and 3 are functioning with wrong numbers and letters. How can we solve this problem using jumpers?
Old 10-19-2013, 21:21   #7 (permalink)
Member: 1359755
Sonork: amimon
Thanks Meter: 4
i have same problem plzzz help...
Old 10-20-2013, 14:32   #8 (permalink)
sumon_tele's Avatar
Member: 1960103
Sonork: 100.1651089
Thanks Meter: 49
boss my same problim.................
Old 10-20-2013, 14:39   #9 (permalink)
Member: 1697969
Thanks Meter: 6
pls change the keypad ic brother
nokia 7270 key 3,6,9 and harsh botten problem barthosyn Nokia Hardware & Hardware Repair 6 07-30-2008 11:27
Water damage W200 where the button 3,6,9 have other function then it should solution. reactos Sony Ericsson Hardware Repair 1 04-16-2008 22:16
t610 keypad fault, keys 3,6,9,#?? jtg Sony Ericsson Hardware Repair 1 02-22-2006 23:56
C100 only 3,6,C and ON/Off key works irfaN_vu Samsung Hardware Repair 4 05-16-2005 14:05
model v150 menu is not work Yashaka Motorola P2k 8 07-06-2004 13:45
Page generated in 0.17977 seconds with 9 queries
