10-27-2002, 17:35 | #1 (permalink) |
No Life Poster Join Date: Mar 2002 Location: khonkean,thailand
Member: 10084 Status: Offline Thanks Meter: 283 | nokia with many problem 3310 phone A.RSSI 112 db Tx with wintesla ok.test with SIM card. (look in net monitor) get 637 -93 but when get * symbol ANT not lightup.and 0 voltage on TX-BUF,PAC-DCS line 3310 phone B.RSSI 116 db Tx with wintesla ok.test with SIM card get random (look in net monitor) 635,637,662,701,703,705752,763 allway 3310 phone C.RSSI 93 db(with one phone 116) Tx with wintesla not work not current consume.in Tx level 5 voltage on TX-BUF line is 0.2V and PAC-gsm line is 0.15V.testwith SIM card get 0 allway 8850 .RSSI 144 db Tx with wintesla not work.i try change 26 Mhz but not help all phone cobba, haggar, ccont, ok .cause i change to new chip i'll wating for help. Last edited by SE-THAILAND; 10-28-2002 at 07:36. |
10-27-2002, 18:07 | #2 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Srtech, measure some 1800 saw filter and antenna switch ! measure that Vtx is supply check TXP is enabe ( high) checkTXC on each TX level ! that you wrote here , it is in 1800 Mhz,, try to see how is GSM 900 working ! Willy |
10-27-2002, 18:17 | #3 (permalink) |
Member: 10084 Status: Offline Thanks Meter: 283 | hi willy for phone A,B i try change antenna switch but not help Vtx is ok (2.8 v) where test piont for TXP,TXC line i try on 900 band but still not work thank for reply |
10-29-2002, 22:02 | #5 (permalink) |
Member: 10084 Status: Offline Thanks Meter: 283 | willy i compare with good phone waveform @ TXC,TXP,C558 ok (all Rx Tx) yesterday i buy secondhand osciloscope HAMMEG HM303-3 maximun 30Mhz.then i check pin 3 of 26 Mhz(G502) get about 200-250 mV and L511 get about 100-150 mV only (test with good phone)posible osciloscope fault ?.but test CAL. piont of osciloscope is ok Last edited by SE-THAILAND; 10-30-2002 at 08:20. |
11-01-2002, 01:34 | #6 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Flash Age: 44
Member: 11208 Status: Offline Thanks Meter: 11 | Willy. Hi. Before you told me you use 250 Mhz OSCILLOSCOPE with 1/10 impadence. So it is okey all Nokia repairing without any trouble? Can it diagnose gsm 900 and 1800 networks? If yes how much does it cost in your country? Also is there anyone who can sell me cheap good RF COUNTER and OSCILLOSCOPE ? Thanks for attentions. |
11-01-2002, 01:37 | #7 (permalink) |
Freak Poster Join Date: May 2002 Location: Perth, Western Australia Age: 45
Member: 11937 Status: Offline Thanks Meter: 1 | Hi I only have a 100mhz scope, and i do basic RF repairs. Instead of seeing a good 900mhz RF waveform, i see either some fuzzy **** or a tiny part of the waveform. It doesnt really matter, since when I test the TX part, all iam watching is the amplitude of the waveform increase as I crank up the PA using wintesla. As for a frequency counter, Sunkko in china are selling one dont know the price though |
11-01-2002, 09:27 | #8 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Gsmsalers, I used Hitachi V1565 , 100Mhz with readout ! and it good test logic side , but not for high frequency ! like Hager IP/QP to COBBA ,100 Mhz is more then enough ! Willy Quote:
11-01-2002, 09:35 | #9 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Srtech, let we say in 3310 : Vp-p of 13Mhz at C303 , it need 600~750 mv ! C558 is for 3310 PLL VCO loop from Hager , you have to set CH in wintesla for RF RX control ! you have to measure RX IP/QP at R504 , and TX from COBBA at R541 and R548 ! then go to measure at T504 TX out from Hager ! Willy Quote:
11-01-2002, 21:47 | #10 (permalink) |
Member: 10084 Status: Offline Thanks Meter: 283 | willy i try measure RX IP, RX QP, TX IN, TX IP, TX QP, TX QN .TXC .TXP line it good work.but no voltage on Vapc line.line not cut or short .i try swap HAGAR chip with good phone but still not work u have idea for other phone ? regard |
11-03-2002, 03:36 | #12 (permalink) |
Member: 10084 Status: Offline Thanks Meter: 283 | willy i said Vapc =voltage automatic power control .at PA to day i get new problem with 3310.it show network few minute then insert sim card on GSM but test TX with wintesla no problem .for DCS work fine .i try change ANT switsh but not help regard Last edited by SE-THAILAND; 11-03-2002 at 04:13. |
11-03-2002, 05:04 | #13 (permalink) | |
Member: 1060 Status: Offline Thanks Meter: 10 | Srtech , try to remove COBBA, and clean all tin ball in PCB pad ! Willy Quote:
MANY PROBLEMS WITH UFS3!!!!plz help!!!! | manouba | UFS2 + UFS3-Tornadoflasher | 14 | 05-19-2011 12:51 |
Too Many Problems With Nokia 6600 | aseemvizag | Nokia Hardware & Hardware Repair | 5 | 05-06-2006 14:43 |
Many Problems with GD87! What depend? | Maurone | Panasonic | 0 | 09-28-2004 16:17 |
many problems with e616 nec !! plz read this!! | manouba | NEC | 0 | 05-27-2004 15:39 |
Many Problem with SilverCard | asky | Sim Cloning and Scaning | 0 | 09-08-2003 07:10 |
