07-30-2013, 18:16 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Age: 58
Member: 1564612 Status: Offline Thanks Meter: 12,343 | NOKIA N8 no power, no connection to PC/BOX tx in advance, Br Max |
07-31-2013, 20:53 | #2 (permalink) |
Moderator Join Date: Jul 2006 Location: Midnapore,West-Bengal,India
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | is it drop down or water damage set ? check battery connector if needed resold or replace . u may also reflow or reball gazoo (power ic ). post result |
08-01-2013, 12:02 | #3 (permalink) | |
Member: 1564612 Status: Offline Thanks Meter: 12,343 | Quote:
I see clean battery connector, where should I resolder, and the Power IC is this?: Pardon but if i enter whith JIG and power external not wok, right? br Max | |
08-01-2013, 13:20 | #4 (permalink) |
Member: 322206 Status: Offline Sonork: 100.1594813/.:SARCAR:. Thanks Meter: 1,350 | here I attach d image , check voltages as shown on picture at marked points . post result |
The Following User Says Thank You to .:SARCAR:. For This Useful Post: |
08-06-2013, 08:58 | #6 (permalink) | |
After i've cecked all voltage in Gazoo and IC signed, have reflow a small the IC, when had connected only Original f/bus cable in contact battery and Jig of pcb, other RJ45 to Atf Box, when improvvise i can see that this DEAD N8 was connecting in f/bus. Have done all test sw, reflashed phone, erase all first, and also USB cable was working. In the first time, i had received , from self test, 4 errores: 1) camera 2) Lcd 3) Touch 4) KELVIN CAPACITOR , minor!! Ok, i understand errores 1, 2 and 3 becouse phone was only whith pcb and any more, after i've assemble it no more these 3 errores. Only this Error to point 4) KELVIN CAPACITOR is always minor from test, What's this?, phone is working normal now, but i think alls problems was be from this component, please can do see where is this in pictures, and or goes changed obbligatory, many thankx BR MAX | |
