09-23-2007, 20:37 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::nokia n80 full short::.. |
09-24-2007, 00:19 | #2 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | hi, hum your saying flty is over charging.....so you need to chcek wher have volt senceses. first targat is um then pa then cpu......all rady your doing job pa but dot hit up on the pa take steep pcb undear saide hit.and pull up the pa after check have a any short in pcb thanks and good luck.................... |
09-24-2007, 00:30 | #3 (permalink) |
Freak Poster Join Date: Sep 2003 Location: FRANCE Age: 42
Member: 39679 Status: Offline Thanks Meter: 41 | Check BETTY AND VILMA IC under battery connector, ( BETTY is charging ic ) if your phone is dead in charge maybe this is the fault , also check VILMA IC it's the power suplier for the phone; post result |
..::6120c dead and full short::.. | HUM | Nokia Hardware & Hardware Repair | 7 | 12-25-2011 22:40 |
..::1100 converted set full short::.. | HUM | Nokia Hardware & Hardware Repair | 0 | 01-13-2008 17:47 |
..::nokia 1100 full shortage in pcb::.. | HUM | Nokia Hardware & Hardware Repair | 3 | 12-29-2007 03:50 |
..::nokia n80 smps ic jumpers needed::.. | HUM | Nokia Hardware & Hardware Repair | 2 | 09-29-2007 16:16 |
..::k700 i put charging ic it show full short::.. | HUM | Sony Ericsson Hardware Repair | 1 | 08-30-2007 02:17 |
