01-15-2005, 09:33 | #4 (permalink) |
No Life Poster Join Date: Sep 2002 Location: max232 chip
Member: 16036 Status: Offline Thanks Meter: 5 | hi seems to me -->hacker5353 have NO idea what his talking about if phone responds to charger this LOGICALLY means "fuse" is ok cliniquegsm try this 1-> charger ok<good type> 2-> battery good 3--> battery PINS conector all ok n clean 4--> check sensor 5-> chaps 6-> ccont should be working by then keep well |
01-15-2005, 11:33 | #7 (permalink) |
No Life Poster Join Date: Jan 2004 Location: United States
Member: 51453 Status: Offline Thanks Meter: 729 | dont do any hardware repair on to your phone. flash your phone again using geoflash by geocadin.coz that not charging problem causes by software.try to flash it again & it will be ok wbr sherwin |
01-21-2005, 18:31 | #10 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | Quote:
in 2100 my experience after flashing i received message "not charging" when i connect the charger can solve by changing the battery connector. i have changed the CCONT, change the fuse, try to check the tracks but the problem not solved. But after changed the battery connector the problem solved. I have found this case in my workhouse 3 times, and the cases was solved by change the battery connector. BR Unggul | |
2100 not charge after flash | abdoulaye | UFS2 + UFS3-Tornadoflasher | 1 | 11-26-2004 17:08 |
2100 not charging | gbada | Nokia Hardware & Hardware Repair | 6 | 11-22-2004 05:26 |
nokia 2100 not charging ???????// | moobile mafia | Nokia Hardware & Hardware Repair | 8 | 10-09-2004 11:27 |
2100 not charging after flash | fgl30 | UFS2 + UFS3-Tornadoflasher | 25 | 09-07-2004 15:45 |
not charging 2100 nokia | adrianteo | Nokia Hardware & Hardware Repair | 3 | 04-02-2004 13:05 |
