12-22-2008, 17:17 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Pakistan (Layyah) Punjab Age: 37
Member: 453862 Status: Offline Thanks Meter: 53 | Plz help me for new 1200 TODAY CUSTOMER PURCHASED THAT MOBILE AND ASK ME TO INSTALL URDU LANGUAGE IN IT I FLASHED IT WITH 4.11 AND BY MISTAKE I DO NOT NOTE PREVIOUS VERSION OF FLASH FILE I USE HWK 2.0.8 WHEN I FLASHED IT SHOW CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile I DOWNLOAD UP VERSION (LATEST VERSION) AND TRY TO FLASH IT IN HWK AND JAF BUT FAILED WHEN INSERT BATT AND POWER ON IT SHOW CONTACT SERVICE WHEN ATTACHED TO FLASHER IT SHOW LOCAL MODE BUT NO UI SETTING AND NO INFORMATION .WHEN FLASHED IT HAVE LOCAL MODE BUT CONTENT FAIL.AT LAST I OPENED THE MOBILE AND FLASH CHIP IS STRANGE TO ME (SEE PIC) IT IS CZ WARRENTED MOBILE PLZ GUIDE ME WHAT TO DO.I WILL BE THANKFUL TO YOU COMPLETE LOGS ARE HERE 1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.0.8.0] 2nd Boot: u3_2nd.fia, Ver: 4.76.0 Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18 Algorithm: u3_intel.fia, Ver: 4.76.0 Algorithm Ok, MSID: 84C90C33E293F6D5C8E9EC9080 Decoded MSID: 3E4EBAE9-001713A1-AA000000 Encoded FAID: 2A8E238E-643C5C4E-4E8426E7 IMAGE: rh99_05.710 Area1: 0x01000000-0x0100FFFF Erasure Skipped Area2: 0x01010000-0x013AFFFF Erasure Skipped Area3: 0x013B0000-0x013EFFFF Erasure Skipped Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds MCU Flashing Completed, Time: 00:19 IMAGE: rh990_nai5.71ej Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01 CNT Flashing Completed, Time: 00:01 Extracting Contents Package ... Init Local Mode Failed Contents Package Extracting Failed: Process Failed, Repowering Mobile |
12-22-2008, 17:34 | #3 (permalink) |
Member: 453862 Status: Offline Thanks Meter: 53 | Brother it is quit new mobile only two minuts it was opened why clean ? I erased full it in jaf and hwk but same it is flash ic pic see it before it u see in 1200? |
12-22-2008, 18:01 | #4 (permalink) |
Junior Member Join Date: Jun 2006 Location: azamgarh
Member: 292138 Status: Offline Thanks Meter: 0 | bro first full erase the phone by jaf and flash with the new version file and write with goog pm pro will solve there is no need to cleane the pcb because phone in new |
12-22-2008, 18:21 | #5 (permalink) |
Member: 453862 Status: Offline Thanks Meter: 53 | Brother understand after full erase when i flash phone in jaf after writting three files it has local mode on the screen but no ui setting are appliled and not unlock when press info button it show mobile is not in local mode |
01-31-2009, 17:28 | #9 (permalink) |
Registered User Join Date: Mar 2007 Location: kotsultan LY pak
Member: 473907 Status: Offline Thanks Meter: 63 | 1ST flash with ub with highest ver. i hope ur prob will be solved 2nd 1 erase 2 flash with highest ver. 3 write pm 4 unlock 5 factory setting All do with jaf NOTE: NOT FLASH WITH LOWER VER. UR SET MAY BE DEAD |
01-31-2009, 17:39 | #10 (permalink) |
Freak Poster Join Date: May 2008 Location: Uganda
Member: 774126 Status: Offline Sonork: 100.1645006 Thanks Meter: 42 | only soft problem bro,dont even trip. just take your time and before you know it, you will have it back on air. or else try flashing with out cnt file and write good pm then unlock with jaf |
01-31-2009, 19:10 | #11 (permalink) | |
Freak Poster Join Date: Jun 2006
Member: 286908 Status: Offline Thanks Meter: 81 | your problem will be solved Quote:
erase fls, if unable to erase fls then hardware problem (upp,uem,flsh, any one) if erase files you must select maual flash > use ini select product > rh 99 - 1200 set ppm lang which you want, then flsh after flsh > factory set full write good pm > then unlock it will be done | |
02-01-2009, 15:45 | #13 (permalink) |
Member: 453862 Status: Offline Thanks Meter: 53 | Brothers all you say flash with higher version one question???? with which version???? This problem solved when i changed the flash chip from a old board i simply flashed it with hwk and solved. Now i have 4 more pieces tried all you say but same......... if some one have higher version which you say plz upload here i have 5.71 for 1200 any update file???? plz share also for 1208 1209 1650 i will be thankful to you |
02-01-2009, 15:50 | #14 (permalink) | |
Freak Poster Join Date: Oct 2006 Location: Lusaka,Zambia,Africa Age: 49
Member: 365744 Status: Offline Thanks Meter: 54 | jst use JAF Quote:
jst use JAF and write a good pm .thats why JAF was made to work on small problems like the one u have . enjoy Br.T | |
The Following User Says Thank You to Temani For This Useful Post: |
02-01-2009, 15:55 | #15 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Estonia Age: 37
Member: 154612 Status: Offline Thanks Meter: 824 | Problem is simple u just downgraded the phone, i think ur problems will be solved by flashing the phone with versin 5.80 (Which is latest available) Br Janar Quote:
hi plz help me im new | abi.m | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 03-30-2010 06:43 |
plz help me to flashing 1200 | abousalma007 | Nokia Hardware & Hardware Repair | 3 | 08-09-2009 14:44 |
plz help me in nokia 1200 | skyhawk78 | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 11-20-2008 14:26 |
plz help me i need 1200 pm file | mangaraj1988 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 07-19-2008 18:34 |
plz help me for my new v-power | amiriratel | VygisToolbox | 1 | 05-07-2007 20:50 |
