08-01-2007, 19:26 | #76 (permalink) |
No Life Poster Join Date: May 2003
Member: 28004 Status: Offline Sonork: 100.1601142 Thanks Meter: 770 | help... any solution ? |
08-02-2007, 10:43 | #79 (permalink) |
Freak Poster Join Date: Dec 2002 Location: South west England Age: 69
Member: 18839 Status: Offline Thanks Meter: 0 | Does anyone know if I can increase the font size of my 6233 I've put all the settings to large font but still the wirting is rather small and I need my glasses to see it. I just wondered if there was like a profile with big letters and numbers or a specific flash that could do the job? Any ideas? I have tried flashing with the latest soft but still the same. |
08-17-2007, 08:09 | #82 (permalink) |
Crazy Poster Join Date: Jun 2007 Location: Baguio City Philippines Age: 42
Member: 531261 Status: Offline Thanks Meter: 36 | bro do you have solution with 6233 taht is ok when w/o sim...but when there is sim it doesnt enter the main menu....stoppes at the hands of nokia onli...is it program?? or is it off line solution?? |
08-17-2007, 12:13 | #83 (permalink) | |
Member: 18839 Status: Offline Thanks Meter: 0 | Quote:
08-22-2007, 10:37 | #86 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | 6233 mmc option missing dear friends, only one drop of water fall on the mmc supply ways & the mmc option is missing. i replaced both the mmc ics but nothing happen. 3.7v from batt & 1.8v vio is present but 2.8v to mmc pin 4 is missing. please help & give solution. thanks |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
08-22-2007, 15:08 | #87 (permalink) |
Freak Poster Join Date: Aug 2007 Location: just learning Age: 45
Member: 560754 Status: Offline Thanks Meter: 289 | Hello all,i have a problem with 6233 the red key/no is failure,before i post this,i already check the keypad way 2 connector main board is ok and i already change the keypad ic but the problem still same!!!have any solution 2 solved my problem????????!!!!!!!! |
09-03-2007, 06:11 | #88 (permalink) |
Junior Member Join Date: Sep 2007 Location: Sihanoukville, Cambodia
Member: 579308 Status: Offline Thanks Meter: 0 | I have 2 problems with my 6233 - First one - The left loudspeaker makes loud crackling noises at moderate volume levels, the right speaker sounds fine. I have tried replacing the troublesome loudspeaker with a new part, but it continues to have the same problem, although it does not appear to be as bad as before. I think maybe the amp's left channel is ****n. Second problem - The external microphone (on the headset) does not work at all. The headset was tested on other phones and the microphone worked fine (so it's a phone problem). I am using a genuine HS-23 headset, and the pop-port on the phone is clean, and undamaged. I have no idea what is causing this. The internal mic works fine, but it's a pain in the *** to have to pull the cord from the phone everytime I want to take a call. My phone is running the latest firmware and other than the loudspeaker and external mic problems, it is in new condition. Thank You! |
help me 6233 auto turn off | heror81 | Nokia Hardware & Hardware Repair | 4 | 03-17-2009 09:28 |
help me 6233 not mmc | anhduy2004 | Nokia Hardware & Hardware Repair | 1 | 07-30-2008 10:41 |
help me 6233 restart problem | edi wijaya | Nokia Hardware & Hardware Repair | 2 | 10-24-2007 06:58 |
Help me 6233 cmt error | pinkzgsm | Nokia Base Band 5 ( BB-5 ) | 0 | 09-26-2007 12:03 |
