Old 12-01-2007, 20:45   #1 (permalink)
Member: 257014
Thanks Meter: 4
probleme bluetooth for nokia 6230.
I need for probleme of bluetooth for nokia 6230,its not activete.
Old 12-01-2007, 22:02   #2 (permalink)
Member: 278058
Thanks Meter: 81
Try to upload a good pm file. If now success reheat/change the bluetooth IC
Old 03-06-2008, 21:12   #3 (permalink)
serseg.gsm's Avatar
Member: 77394
Thanks Meter: 118
this solution not work for me,
is there any other solution,
about problem: when select (activate .... nothing happen... BT steel desactivated)... when selectet desactivate message of confirmation appeared like that bt was activated before.
tryed with full flash + g.pm , reheat Bt module, without success
Old 03-07-2008, 03:53   #4 (permalink)
Registered User
Member: 171336
Thanks Meter: 61
Cool
replace the blue tooth module thats all
Old 03-07-2008, 16:10   #5 (permalink)
serseg.gsm's Avatar
Member: 77394
Thanks Meter: 118
thats all , nice, thanks
Old 03-07-2008, 16:17   #6 (permalink)
Member: 244357
Thanks Meter: 70
first no make hardware ,connected with jaf box and make repair-bt , i solved this problem two times
Old 03-07-2008, 19:39   #7 (permalink)
serseg.gsm's Avatar
Member: 77394
Thanks Meter: 118
i did with ufs, not help
Old 03-07-2008, 19:45   #8 (permalink)
Member: 37311
Thanks Meter: 2
chaning pm..............
Old 07-10-2008, 14:30   #9 (permalink)
Member: 691395
try to do that with mtbox in the software you will found 'fix bleutouth' buttom..........
Help to repair bluetooth on Nokia 6230 rh-12 !!! Unlocker_001 HWK 2 08-07-2009 16:27
Problem to flash Nokia 6230 Dayratel Phoenix Black Box 3 07-15-2005 14:07
Plz Help For Nokia 6230 Keypad Problem Mobile Master Pk Nokia Hardware & Hardware Repair 2 06-03-2005 09:56
Plz Help For Nokia 6230 Keypad Problem Mobile Master Pk Nokia Hardware & Hardware Repair 1 06-02-2005 22:20
Looking for JAVA application for nokia 6230 intsik Java, iOS, Android, Symbian development 0 07-07-2004 15:36
Page generated in 0.24131 seconds with 9 queries
