04-28-2006, 06:06 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: Dombivli (E) Age: 48
Member: 124938 Status: Offline Thanks Meter: 69 | Requesting help for N3120 I connected it to ufsx, it showed me "1st boot ok". Then while getting info it doesn't responded, so I thought that this may be a software problem. So I clicked on "Erase" button. While erasing it stucked with an error as "Error Erasing Area 4 Process failed Repowering Mobile". At this point, I heated the Flash IC with good flux. Then I changed the "skip area" in UFSX from 9 to 6, and then after clicking on "Erase", it erased properly. I flashed the phone with latest MCU's and PPM and was completed successfully. But still no power. After this process again If I click on Erase then it shows an Error "Out of Chip Bounds". I can't figure out what wrong I am doing? Flashing MCU and PPM is OK but still no power. I checked voltages at the LCD connected, I am getting 2.6 v only at the first point from right side top. Can anybody help me? Thanks If require I will post the exact output of UFSx |
05-01-2006, 05:42 | #2 (permalink) |
Member: 124938 Status: Offline Thanks Meter: 69 | LCD was faulty, LED booster coil was faulty and same was replaced and everything is ok now. But when booting the mobile in normal mode (UFSx) It shows "Insert Sim Card" but after connecting battery it shows "Contact Service" Any solution for this? Thanks Ajubaba |
05-01-2006, 08:35 | #3 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: PHIL
Member: 197247 Status: Offline Thanks Meter: 296 | Quote:
05-02-2006, 05:44 | #4 (permalink) |
Member: 124938 Status: Offline Thanks Meter: 69 | Thanks for replying. I just given a slight jerk to the flash IC. Now when battery is connected it shows "contact service". But while in normal mode in ufs it shows "Insert Sim card". Any more help? |
Request help for becker 2000 avus | kensat | CAR Electronics | 3 | 10-24-2009 14:00 |
Req: LCD ways for N3120 | ajubaba | Nokia Hardware & Hardware Repair | 1 | 06-05-2006 07:48 |
Request help for N6600 (curious problem) | gkaraan | Nokia Hardware & Hardware Repair | 1 | 12-29-2005 20:11 |
need help regarding N3120 | moottoo | Nokia Multimedia | 2 | 06-02-2005 13:15 |
Requesting Help For Downloadingn Movies To Phone | dewo_333 | Nokia Multimedia | 4 | 12-13-2004 17:11 |
