04-14-2009, 00:53 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Age: 46
Member: 138020 Status: Offline Thanks Meter: 87 | Rf in all nokia bb5 part 1 : in mobiles contents helgo (rf) sutch as 9500 N9500 CMT RF training Content General N9500 RF Implementation Block diagram Power distribution Helgo86G, PA & Antenna Switch Module Engine PWB Location of the RF Key components TX layout TX GSM and EDGE operation GMSK and 8PSK block diagrams TX tunings in EDGE General 9500 RA-2: 900/1800/1900 MHz GSM/EDGE US 9500 RA-3: 850/1800/1900 MHz GSM/EDGE N9500 RF Implementation Starting point was N3220 (Jesse) RF implementation Several RF Keycomponents as in N3220 / N3200 (Rio) ( = Trinity 1 Engine, BOM1 ): PA (Renesas ) TX (1pcs) / RX (3pcs) filters VCO VCTCXO RFIC changed to Helgo86G, TFBGA88 package 6x6 mm2 ( Helgo73, TFBGA108, 8x8 mm2) Small differencies to external discretes around Helgo 9500 specific PWB placement GPRS MSC10 feature added ( N3220 MSC6 , N3200 MSC10 ) EGPRS MSC10 feature added ( N3220 MSC2, 2+1 max RX + TX slots ) 3+2 / 4+1 max RX+TX slots 2 TX slot EDGE functionality Power scaling is used in GMSK TX dual slot function (2 * TX slot) 900 GMSK: 32.5 -> 29.5 dBm 1800 GMSK: 29.5 -> 28.5 dBm 1900 GMSK: 29.5 -> 28.5 dBm 8PSK powers are same in single and dualslot RF Frequency Plan Power distribution VR1...9 & VrefRF01 voltages from UEM Vbatt from battery Vr1-----pll chrge pump (4.8)v Vr2----tx modulators,vpectrl3s(alc).driver Vr3---vctcxo.synthesizer digital parts Vr4—helgo pre-amps.mixers.dtos Vr5—dividers.lo-buffers.prescaler Vr6--- linas.helgo baseband (vdd-bb Vr7--- vco Vrefrf01--- ref.v0ltage for helgo Vrefrf02 Vbatt -------pa |
The Following User Says Thank You to nalkershy For This Useful Post: |
04-14-2009, 01:01 | #2 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Helgo86G TFBGA88 package 6 mm x 6 mm body size (typical) 0.5 mm ball to ball grid GMSK (GSM) and 8PSK (EDGE) functionality Receiver: 850/900 & 1800 LNA integrated 1 demodulator (mixer) / band (3 pcs) Channel selection filter BB amplifiers for I/Q signals amplification Transmitter: One I/Q modulator for 850 or 900, the other one for 1800 & 1900 ALC stages and buffers SHF range PLL Power control block Power Amplifier Module (PA) PF09003BN for RA-2 (900/1800/1900) PF09009BN for RA-3 (850/1800/1900) GMSK / 8PSK functionality Antenna switch module (ASM) 3 control signals Vant1 ... 3 3 RX output and 2 TX inputs Based on diode switches |
04-14-2009, 01:07 | #3 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | 9500 1bt engine (top side) Location of the RF Key components TX layout TX GSM and EDGE operation GMSK operation Control voltages TXC, TXP are used for TX 8PSK (EDGE) operation Control voltages TXC, TXP are used together with IREF and TXA PA mode (GMSK/8PSK) is selected by MODE |
04-14-2009, 01:11 | #4 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | TX GMSK operation TX Block diagram TX 8PSK operation Items in EDGE tunings with Phoenix SW I/Q tuning same settings and procedure as in GSM tuning Power level tuning ALL POWER LEVELS HAVE TO BE TUNED SEPARATELY !! |
04-14-2009, 01:40 | #7 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | GSM Transmitter WCDMA Transmitter Power Control Loop – WCDMA Transmitter 1/2 TXC is used to drive the VGA which is used as the “main power controller” The PA outside is just for the final setting of the outgoing power WCDMA uses closed loop SW power control, where the Base Station will provide information for the terminal to increase or decrease its power by 1 or 2 dB steps Power Detection: It is required that terminal must be able to measure its output power in high power level. The power detector measure it and fed a voltage (WTXDET) back to RETU to undergo AD conversion Output power needs to be limited to +21 dBm Isolator: It passes RF power only in one direction. Without it, RF power may leak in and affect the output of the detection circuit, resulting in error in the power control loop Power Control Loop – WCDMA Transmitter 2/2 SMPS: The supply voltage of the PA and limits the lowest supply voltage to 1.5V. At highest power levels the SMPS output settles nominally to 3.2V The supply voltage and the reference current lines (DAC 101 and DAC 201) are used to set the PA to distortion-free gain according to PA vendor's specification; this is essential in WCDMA Synthesizers |
04-14-2009, 01:44 | #8 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | Phase Lock Loop (PLL) The output of the phase det depend on the phase of the measured frequency compared to the phase of the reference frequency PLL charge pump charges or discharges the integrated capacitor in the loop filter based on the output of the phase det (comparator) Key Components 0f WCDMA Receiver Why do we need Additional Filtering? This SAW filter is to attenuate the Tx signal which is leaking through the duplex filter and amplified by the LNA Why do we use duplexer instead of antenna switch? This is because Tx and Rx are functioning in continuous mode in WCDMA What is the use of AGC stage? This stage is used to maintain the voltage swing at the AD converter in BB at an adequate level Power Control Loop – GSM Transmitter Power Detector Circuitry in PA gives a DC value proportional to the output power DC level is feedback to the negative input of ERROR amplifier in VINKU The DC level is then compare with the TXC reference signal The output of the ERROR amplifier is then fed to a buffer amplifier which drive the VGA |
04-14-2009, 02:01 | #9 (permalink) |
Member: 138020 Status: Offline Thanks Meter: 87 | part 2 AHNE WE TALKK ABOUT 6300 THE RF CHIP INSIDE OF NOKIA 6300 IS ACHIP CALLED AHNE> AHNE CONTAINS FOLLOWING FEATURES AND FUNCTIONS INSIDE: - MIXER FPR RX - LNA(LOW NOISE AMPILIFIRE -BB GAIN AMPLIFIRE - DC COMPENSATION FOR RX -PLL FOR EXTERNAL OSCILLATOR -CURRENT TO VOLTAGE CONVERTOR(IN TX) -TX MIX -TX PREAMPLIFIRE - TX POWER CONTROL -REFERENCE VOLTAGE AND CURRENT SOURCE -SYSTEM CLOCK BUFFER -INTERNAL VOLTAGE REGULATOR 6300 (RM-217) RF Block Diagram |
all nokia bb5 blue & white screen in one thread please | sazr | Nokia Hardware & Hardware Repair | 13 | 12-23-2009 21:46 |
