01-31-2009, 19:22 | #6 (permalink) |
Freak Poster Join Date: Apr 2007 Location: Inside War
Member: 496508 Status: Offline Thanks Meter: 59 | 1112 rh 94 Nokia 1112 rh 94 INFO Getting MCU ID MCU ID: 0x2292 FLASH ID0: 226800EC <=> SAMSUNG(SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 3.00 19-12-06 RH-94 (c) NMP HW version: 0501 PCI version: UEM version: 2339 UPP version: 8850 RFIC version: 0700 DSP version: GDSP_P06w45.v8 LCD version: SDI:SYRSv00 LDS162 PPM version: V 3.00 19-12-06 RH-94 (c) NMP ME ADSP SW version: V 3.00\n19-12-06\nRH-94\n(c) NMP\nme Production serial number: DPA674517 Product code: 0543479 Module code: 0203117 Basic production code: 0534738 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 3545500105389XX IMEI spare to net: 3A 45 55 00 01 35 98 08 IMEI SV to net: 33 45 55 00 01 35 98 08 F4 Master Code: 2547430115 Phone type: RH-94, Software version: 3.00, Language Pack: ME User code: ÿ# Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RH-94.ini Saved INI not found, loading INI list... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: \Products\\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done WHEN READ IMEI Booting phone... MCU ID: 0x2292 Sending algo... Algo is ready... P-key nokia module version 01.02 Reading... Error loading cbus loader... Setting local mode... Failed! Aborting! |
02-01-2009, 11:14 | #7 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: \/\/ 0RLD \/\/ IDE
Member: 238374 Status: Offline Sonork: 100.1597005 Thanks Meter: 1,087 | Quote:
brother try with jaf latest version and post here rezul | |
02-03-2009, 09:28 | #8 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: bukittinggi
Member: 526318 Status: Offline Sonork: dc2000 Thanks Meter: 42 | Quote:
1112 Rh94 | ryaz1993. | Universalbox | 4 | 03-14-2007 08:31 |
1112 RH94 "new" Flash files needed?...... | citylight | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 03-02-2007 21:07 |
