Old 06-16-2007, 09:42   #1 (permalink)
Member: 84648
Thanks Meter: 3
7610 start up appear only " NOKIA" ?
please
nokia 7610 appear on lcd only " NOKIA " and no continue startup ?
1. software ok
2.format ok
3.ui settings ok
4.erase flash 0k
5. read UEM ok
any idea please
thaks
Old 06-16-2007, 09:47   #2 (permalink)
meo786pk's Avatar
Member: 465162
Thanks Meter: 683
format user data area
Old 06-16-2007, 10:36   #3 (permalink)
Member: 84648
Thanks Meter: 3
thank you i format user data area but nothing
Old 06-16-2007, 10:51   #4 (permalink)
Jr Telecom's Avatar
Member: 409725
Sonork: 100.1581478
Thanks Meter: 797
Did u try to format mannually?( *-3-sendkey-power)
____________________________________________
Not yet Hardware problem.....
Old 06-16-2007, 11:18   #5 (permalink)
makkah mobile's Avatar
Member: 226363
Sonork: 03--4899925
Thanks Meter: 569
its a hardware problem dear.. rehot the board
Old 06-16-2007, 11:37   #6 (permalink)
Member: 84648
Thanks Meter: 3
i format manually , but nothing
thanks
Old 06-16-2007, 14:33   #7 (permalink)
Member: 137686
Thanks Meter: 3
Originally Posted by eng.hamdow View Post
please
1. software ok
2.format ok
3.ui settings ok
4.erase flash 0k
5. read UEM ok
any idea please
thaks
Reball the UEM ic. thank's
gud luck
Old 06-16-2007, 15:57   #8 (permalink)
Jr Telecom's Avatar
Member: 409725
Sonork: 100.1581478
Thanks Meter: 797
thanks
SO,Definately hardware........................May b UEM
Old 06-16-2007, 17:19   #9 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
HI M8T YES CHECK H/W UEM AND UPP ................!
..::Mr Fone::..
Old 06-17-2007, 07:34   #10 (permalink)
Member: 154916
Thanks Meter: 4
hi pro reheat UEM & UPP
B.R
Begato2002
Old 06-17-2007, 11:32   #11 (permalink)
Member: 281448
7610 "NOKIA" on the screen
take tese steps andd it will be soleved
1. do full fasctorty defaults
2. swith to normal mode
3.swith to local mode
4.do format user area
5. and switch to normal mode
best regards
Old 06-17-2007, 11:38   #12 (permalink)
markrhi's Avatar
Member: 520956
Thanks Meter: 12
bro, just flasherase it in griffin silver 3.086 version then reflash w/ latest firmware then write good pm..if not ok just reheat the flash ram..all will be ok..
Old 06-17-2007, 12:21   #13 (permalink)
JHON_DREAM's Avatar
Member: 310330
Sonork: 100.1577334
Thanks Meter: 1,449
HI every body .
its hardware problem.
just rehot UEM ic. problem will be solved.
best of luck.
BR,
JHON.
Old 06-17-2007, 13:14   #14 (permalink)
kanwal's Avatar
Member: 496736
Thanks Meter: 17
reheat ram and flash it with jaf latest file format user area it is ok repl answer
Old 06-22-2007, 16:49   #15 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
Best solution for 7610 hang on nokia.see my picture.
The Following User Says Thank You to chandy pok For This Useful Post:
7610 start up failer burraq WD2 & APE (Symbian Phones) 12 04-18-2009 18:02
E90 FLASH but DISPLAY ONLY " NOKIA" denard HWK 9 07-05-2008 17:37
7610 start up fail amitks_in Nokia Hardware & Hardware Repair 11 09-04-2006 10:36
7610 start-up failed affter 30min pwoer off ashrafcell Nokia Hardware & Hardware Repair 6 06-11-2006 09:50
7610 start-up fail kenichi Twisterflasher 7 07-16-2005 15:19
Page generated in 0.35104 seconds with 10 queries
