04-21-2011, 01:17 | #4 (permalink) |
No Life Poster Join Date: Jun 2007 Location: INDONESIA
Member: 527741 Status: Offline Thanks Meter: 355 | The following are standard capacitor values. Values below 1 uF are generally available with a 5 or 10 percent tolerance. Values over 1 uF are generally available with a 10 or 20 percent tolerance. Values are in Farads with p = pico, n = nano, u = micro, and m = milli. 2.2p 22p 220p 2.2n 22n 220n 2.2u 22u 220u 2.2m 22m |
04-21-2011, 08:30 | #9 (permalink) |
No Life Poster Join Date: Aug 2006 Location: Cel_Phon - M.B.Din
Member: 328187 Status: Offline Thanks Meter: 1,687 | no need any thing.......just short if coil is faulty in picture those r not capacitors........these are coils if a coil use in voltage section so it will pass to DC but block AC signals ..... yes u can say its a opposite of capacitors |
The Following User Says Thank You to imran zafar For This Useful Post: |
04-21-2011, 09:44 | #10 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Punjab , INDIA
Member: 153805 Status: Offline Thanks Meter: 325 | @HUM you talking about are coils of 2.2uH (H = henry) coils.If this coils are in switching circuit (DC to DC converter) than you should use exact number or voltage generated will be different.If these are in supply line for ripple rejection you can use jumper. Last edited by baldev; 04-21-2011 at 09:51. |
The Following 2 Users Say Thank You to baldev For This Useful Post: |
04-21-2011, 09:56 | #11 (permalink) |
No Life Poster Join Date: Mar 2007 Location: (UAE)(pak)
Member: 479496 Status: Offline Sonork: 1592751 Thanks Meter: 404 | yes it right coz if is capacitors must be( _) (+) there r coil only make vold clean and stable if there capacitors they wright UF not u |
The Following User Says Thank You to GSMTURBO For This Useful Post: |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-26-1999 01:00 |
