09-16-2002, 07:55 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | Strange Problem with 3310 but when i connect to charger it charges, I changed POWER SWITCH, no result! Switch works, cause i can write and read flash from phone, also phone is ok, but not powering on! any help? |
09-16-2002, 21:35 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | take care make a jumper from the forth leg in switch on/off .. to the point number one in the eight point under the key points at the botom left of the board |
09-16-2002, 23:35 | #3 (permalink) |
Insane Poster Join Date: Jul 2002 Location: Egypt Age: 45
Member: 14194 Status: Offline Thanks Meter: 4 | Hi ARC check if the switch is connected with r402 it's right of the antenna switch out of frame if not connect then mack jumper if connect then check if r402 is connected with v414 in right if not then macke jumper if connected then chang r414 r415 if not then replace ccont goodluck Wesam |
strange problem with 3310......... | Gr8SightMan | Twisterflasher | 7 | 08-04-2006 07:46 |
Very strange problem with 3310 | ab1009 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 05-24-2003 13:13 |
very strange problem with 3310 | johny3310 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 12-08-2002 18:37 |
Attention! Strange problems with 3310 after flashing | roller | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-29-2002 03:27 |
Strange problem with Nokia 3310 | Chawek | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 02-27-2002 22:47 |
