Strange Problem In 8210 Display HELP!! Hi All, I recieved a strange problem in a 8210-given for repair yesterday . The moment I try to enter into the phone book or the Profile menu the display goes blank. The lcd is perfectly ok because I changed it with a new one and had the same problem.......... I've tried flashing it but with the same result. Any ideas?? It behaves as if it cannot handle more than a certain amount of Pixels on the display. the moment I press any key(1 to 0) more than 8 times .......the display goes blank. I'm perfectly sure that the display and contacts are ok because it is a new set. Waiting for a solution. Regards, themobileking :cool: :cool: :cool: :cool: :cool: :cool: |
try to change display type prefferably with contrast diodes fitted on it. If doesn't help, use display without diodes. |
thanks for the idea .I'll try that |
Hallo, i have the same problem and we know it can be repaired by changing the lcd to the older type , but i want to ask if it can be repaired without changing lcd 'cause i think it is not so good and efficient to throw the new type lcd to trash - i have here about 50 pieces of them. Thanks Ianek |
hanoon© i think u r right ...im looking for same solution.. |
PROBLEM SOLVED....IT WAS THE LCD . CHANGED IT TO THE OLDER ONE WITHOUT DIODES...........NOW ITS PERFECT. |
