Temperature for safe desolder? Hi, all. Interested in temperature to desolder components. Was trying to remove flash ram ic 7610. But dont seems to get loose. What temperature i can try without destroying it? thanks Sjakie |
normally around 320 degree |
Hi, i tried too 330 degree, but still no movement :( no waterdamaged. regards Sjakie |
u must put some flux in order to remove anything |
be carefull because newer phones uses lead free solder balls and requires more heat to melt it,otherwise you will tamper the solder clads of the board. |
Hi, always use flux... But even 330 degree wont move it :( My main concern which temperate the glass flash ic will survive? |
me use near abt 390 to 420.... its help for me... |
Hi! I use 340-360 degrees for lead-free soldering, but you must consider different calibrations of each soldering station, i mean the indicated and the real temperature may differ. |
Hi, thanks for reply. If i understand ok, i could go up too 350 degree? thanks Sjakie |
without any doubt :) |
Thanks. If anyone have more safe solder temperature, for example plastic PFO i would gladly learn :) regards Sjakie |
