07-31-2005, 14:25 | #1 (permalink) |
No Life Poster Join Date: Jan 2000 Location: NL Age: 55
Member: 847 Status: Offline Thanks Meter: 36 | Temperature for safe desolder? Interested in temperature to desolder components. Was trying to remove flash ram ic 7610. But dont seems to get loose. What temperature i can try without destroying it? thanks Sjakie |
07-31-2005, 16:15 | #5 (permalink) |
No Life Poster Join Date: May 2001 Location: Manila, Philippines Age: 53
Member: 4408 Status: Offline Thanks Meter: 5 | be carefull because newer phones uses lead free solder balls and requires more heat to melt it,otherwise you will tamper the solder clads of the board. |
08-02-2005, 06:27 | #8 (permalink) |
Freak Poster Join Date: Dec 2003 Location: Russia, Yaroslavl Age: 43
Member: 46415 Status: Offline Thanks Meter: 16 | Hi! I use 340-360 degrees for lead-free soldering, but you must consider different calibrations of each soldering station, i mean the indicated and the real temperature may differ. |
What temperature for remove BGA? | Sakura | RE-7500 Reworking System & iSolder | 3 | 09-19-2007 18:44 |
what is good temperature for tp of siemens cf110 | JAVA Good | Siemens Hardware Repair Area | 0 | 08-27-2006 14:06 |
what is beter box for safe flash for bb5 | hanen | Nokia Base Band 5 ( BB-5 ) | 16 | 10-17-2005 05:14 |
what is the ideal temperature for hotair? | sapatos | Hardware Repair by brands | 8 | 08-30-2005 09:52 |
precaution for safe flashing in dct4 | wagdy | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 10-26-2004 20:08 |
