05-04-2008, 08:14 | #1 (permalink) |
Junior Member Join Date: May 2008
Member: 765316 Status: Offline Thanks Meter: 10 | testMode---- Local mode ----Normal Mode There are three conditions for Mobile 1 - Test Mode And is used when the desire to break any codes or the work of your choices UI Options 2 - Normal Mode It Modena in which it operates Mobile normally sends and receives ...... Etc. 3 - Local Mode Moody is used when the FLECHE ======== The basic program is to move between these Modz automatically and without interference of us But in some cases, solving some problems in the intervention and a change Maud private telephone manually Among these problems 1 - Action Reset User Lock or Full Factory Defaults for some telephone such as 2300 or 1100 to transform a symbol of protection to the code 12345 and the abolition of protection This gives the program has been implemented, but does not accept the code 12345 To solve this topic is chosen test Mode and then followed Reset User Lock or Full Factory Defaults in this case we find that the phone responds to is actually shifting to 12345 2 - sometimes come to us, such as Tel 6600 when its operation shows Nokia word on the screen and then disappear and show a white screen This defect there are some people that addressed the full download software, but smaller than a defect that does not require the full and soft, through Norman Hand work of a Mobile If the defect as we connect the phone to Epoxy then select Normal Mode operated by phone, and engage in the Normal Mode and this solve the problem without downloading software But if this method failed can download the software again mohamed el-3adawy thanks.......... |
The Following User Says Thank You to flash-mobi For This Useful Post: |
solutions can't local mode,test mode,normal mode after reflash in here | uwenk98 | Nokia Hardware & Hardware Repair | 30 | 07-27-2013 11:27 |
flash,local mode,test mode,normal mode big problem need help | gsm_cdma_ufs | Nokia Hardware & Hardware Repair | 0 | 04-10-2009 10:50 |
N70 using Fbus cable local mode,normal mode ok,flashing ok...but could not power on | denadio | Nokia Hardware & Hardware Repair | 3 | 07-16-2008 21:17 |
some doubts regarding local,test,normal modes-help | zonetrichur | J.A.F. Plus | 3 | 01-19-2008 18:47 |
Test mode, Local mode Normal mode | royke | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-13-2002 11:33 |
