A Trick For Nokia HAI, I TRY AN EXIPIREMENT IN NOKIA PHONES THAT IS ,I REMOVED ANTENNA SWITCH AND SHORT TX&RX&ANTENNA CONNECTIONS . PHONE REGISTERING NETWORK AND WORKING GOOD . BUT PHONE WORK IN SINGLE BAND .......... dear friends some members send me mail to ask me about this trick Some one write this will distroy phone ,oters ? where is first pin .First i tell you this connection make no trebbles in your phones if such trebble occours please send your replaies to me . This is the connection for antenna switch first pin is earth (down) total 16 pin switch .900mhz transmissoin short 6&12&16 connection .For 1800mhz band short 2&5&12 connection This methode onely work in nokia phones |
Sorry for some stupid question, but how to count RX/TX/ANT legs on diplexor (ant.switch)? Where is the first leg? |
Re: A Trick For Nokia Mandu MIX TX with RX with ANT, i do not thing this is correct way to make phone work! think, about TX power will go back to RX ...... Willy Quote:
hi, i think what you are trying to do is destroying the phone nokia would not put the antena switch there if it has no purpose, |
i think a double diode will work for ant switch , as it is seen in alcatel be4. |
yes it works |
Re: A Trick For Nokia Quote:
Hi,Mandu Where is exactly pin 2,5&12 for 1800mhz, pls give us the layout TQ |
it work I connected Pin 16 to 12 ( GSM in to Antenna Out) , because I was not sure about the pin Numbering , But I think it's like that : -Pin 16 go to PF8109 GSM Out ( pin 6) -Pin 12 of diplex Goto antenna -Pin 6 ( RX ? ) So refering to pin 16 , and by reverse counting , you'll get others pin. Of course counting is same for any 16 Pin IC. I didn't use pin 6. I made mesurement on 4 phones (3310) but in 2 phone, I saw a ground shorted to Pin 16 of diplex , So I isolated the diplex input from the PA , then Made a Jump from the PA to Pin 12 of diplexer , I got Network & phone is working. I'm in a 900 net , don't know about 1800 I know that this is not a famous way to repair a Nokia 3310 network , but it can help people who don't have acces to Hot air tools , Mini Lab, Oscillo & so on. It seem to be better than leting dozen of phones with no net. Now if somebody can explain why it work , and how to test the diplexer offline with just a Multimeter , because I think this solution work on phone who have diplexer faulty. It will not work if the Pa or if the firmware is not good. I'm interrested by a Block diagram of Nokia 3310 RF system ( TX & RF Path). Thanks |
