10-30-2002, 20:35 | #1 (permalink) |
Freak Poster Join Date: Oct 2002 Location: INDIA
Member: 17243 Status: Offline Thanks Meter: 13 | A Trick For Nokia Last edited by mandu; 11-01-2002 at 19:11. |
The Following User Says Thank You to mandu For This Useful Post: |
10-31-2002, 06:33 | #3 (permalink) | |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | Re: A Trick For Nokia Mandu MIX TX with RX with ANT, i do not thing this is correct way to make phone work! think, about TX power will go back to RX ...... Willy Quote:
11-07-2002, 04:13 | #7 (permalink) | |
Freak Poster Join Date: Jul 2002 Location: GSM-FORUM
Member: 13726 Status: Offline Thanks Meter: 1 | Re: A Trick For Nokia Quote:
Hi,Mandu Where is exactly pin 2,5&12 for 1800mhz, pls give us the layout TQ | |
11-21-2002, 04:42 | #8 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Burkina Faso
Member: 7843 Status: Offline Thanks Meter: 1 | it work I connected Pin 16 to 12 ( GSM in to Antenna Out) , because I was not sure about the pin Numbering , But I think it's like that : -Pin 16 go to PF8109 GSM Out ( pin 6) -Pin 12 of diplex Goto antenna -Pin 6 ( RX ? ) So refering to pin 16 , and by reverse counting , you'll get others pin. Of course counting is same for any 16 Pin IC. I didn't use pin 6. I made mesurement on 4 phones (3310) but in 2 phone, I saw a ground shorted to Pin 16 of diplex , So I isolated the diplex input from the PA , then Made a Jump from the PA to Pin 12 of diplexer , I got Network & phone is working. I'm in a 900 net , don't know about 1800 I know that this is not a famous way to repair a Nokia 3310 network , but it can help people who don't have acces to Hot air tools , Mini Lab, Oscillo & so on. It seem to be better than leting dozen of phones with no net. Now if somebody can explain why it work , and how to test the diplexer offline with just a Multimeter , because I think this solution work on phone who have diplexer faulty. It will not work if the Pa or if the firmware is not good. I'm interrested by a Block diagram of Nokia 3310 RF system ( TX & RF Path). Thanks |
Another trick for nokia 1600 with "insert sim" | stefani | Nokia Hardware & Hardware Repair | 14 | 08-24-2013 11:17 |
Tips 'n' Tricks for Nokia S60 Phones | SnowmanDK | Nokia Multimedia | 16 | 04-21-2005 16:57 |
Any Have Trick For Pa Jumper For 1100 | ulymar | Nokia Hardware & Hardware Repair | 3 | 01-16-2005 15:42 |
littel trick for nokia phone | SE-THAILAND | Nokia Hardware & Hardware Repair | 5 | 11-01-2002 21:18 |
