Old 06-16-2004, 18:34   #1 (permalink)
jab
Member: 12386
Thanks Meter: 18
3200 blue screen
hi all,
i have a nokia 3200 which has a dark blue screen when i switch on. i have tried several new lcds but still the same, the phone from inside is clean and free from water damage. i can use the phone but cant see.
can someone please help any solution to this problem
thanks
jab
Old 06-16-2004, 18:38   #2 (permalink)
smartecs's Avatar
Member: 42370
Thanks Meter: 32
most of the problem cause by drop, try to check the signal from upp ,that means the resitor beside power on switch!
Old 06-18-2004, 22:27   #3 (permalink)
Member: 11926
I have same problem with a 3200....
smartecs : can you please tell me wich is that resistor ????
Old 06-19-2004, 17:24   #4 (permalink)
keany's Avatar
Member: 67419
Thanks Meter: 237
you must change or move upp its a most valid solution
Old 06-22-2004, 18:04   #5 (permalink)
smartecs's Avatar
Member: 42370
Thanks Meter: 32
there got small resitor beside the on\off switch (upper part of the power amp), just check it ...
Old 10-14-2004, 13:11   #6 (permalink)
Member: 83893
I have one with same problem, screen lights up but remains blue. already checked the resistors besides and below the on/off switch, everything looks alright but phone still reacts the same even after reflowing these resistors...Should i try reflowing something else? :P thanks
Old 10-15-2004, 14:35   #7 (permalink)
Member: 83893
I have even tried s/c the resistors to see screen reaction but still the same remains blue..any tips?
Old 10-15-2004, 19:15   #8 (permalink)
rirou's Avatar
Member: 85312
Sonork: 1576920
Thanks Meter: 35
iv got the same problem in 5100 that happened when I replaced the on-off switch
Old 10-16-2004, 19:45   #9 (permalink)
Member: 83893
Can anyone with a service manual fro 3200 read the resistor values and put these values here?It looks to be a very common problem..
Old 10-03-2005, 22:42   #10 (permalink)
Member: 184459
Thanks Meter: 4
The resistor is R309
so r=resistor and 309=309 ohm
Old 10-03-2005, 23:35   #11 (permalink)
Member: 143156
Thanks Meter: 95
try change screen or remove screen and erasse flash and fullflash
Old 10-04-2005, 08:41   #12 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
As the other guys said you have to check the resistors named:
R308
R309
R310
And all of them are 220 Ohms and NOT 309
Check them or resolder them and you will be fine
Old 10-06-2005, 11:23   #13 (permalink)
GsmMunna's Avatar
Member: 66937
Thanks Meter: 5,053
hi
HELLO
PROB OF DRY SOLEDRING PLE CHEAK JACK AGAIN BOTH DISPLAY AND BOARD..... WILL BE OKI
WBR
MUNNA
+9810626677
[email protected]
www.gsmmunna.com
Old 10-28-2005, 11:20   #14 (permalink)
Member: 90058
Thanks Meter: 97
mr leo your pic for only 3100 not for 3200 ,and the 3200 look lick 7250 the same ,
Old 10-28-2005, 16:33   #15 (permalink)
leosedf's Avatar
Member: 33547
Thanks Meter: 17
Those pics are from the nokia 3200 service manual. Try to double check before you post
Blue 351x Blue Screen omkarvitekar Infinity-Box 2 08-21-2008 17:53
3200 blue screen and can`t flash swirek Nokia Digital Core Technology 4 ( DCT-4 ) 1 10-20-2006 10:40
nokia 3200 blue screen fonzek Nokia Hardware & Hardware Repair 0 10-06-2005 09:38
3200 Blue screen mujie Nokia Digital Core Technology 4 ( DCT-4 ) 2 10-03-2005 19:53
3200 blue screen gorjanm Nokia Digital Core Technology 4 ( DCT-4 ) 0 09-08-2004 23:18
Page generated in 0.22809 seconds with 10 queries
