01-13-2005, 10:09 | #1 (permalink) |
Freak Poster Join Date: Aug 2002
Member: 14259 Status: Offline Thanks Meter: 2 | UEM can be replaced? Is the UEM for Nokia phones common/same? or I ask like this: 3100 is GSM phone; 3105 is CDMA phone; but their UEM chip is the same? can be replaced each other? BR Woods |
01-13-2005, 10:29 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: Lithuania Age: 40
Member: 19265 Status: Offline Thanks Meter: 92 | But IMEI stored in UEM are different. So as a result you will have - IMEI ????????... You have to change UEM and FLASH from other phone, or use griffin server to repair flash IMEI. B.R. Alkapone |
01-13-2005, 11:31 | #4 (permalink) |
Member: 19265 Status: Offline Thanks Meter: 92 | Glued or not glued, no difference, all can be replaced. Some types are different, but in most caces you can use them. All problem in IMEI, because in OTP programmed imei cannot be changed, so you have to repair flash imei. B.R. Alkapone |
01-13-2005, 11:36 | #5 (permalink) |
Freak Poster Join Date: Dec 2004 Location: SLOVAKIA Age: 46
Member: 97820 Status: Offline Thanks Meter: 4 | with glued UEM we have 50% luck With glued UEM we have 50% luck cause pcb can be damaged when you are replacing ... @Alkapone do you have 100% luck with glued UEMs like 6600,6100,6310 ? ? |
01-13-2005, 11:46 | #6 (permalink) |
Member: 19265 Status: Offline Thanks Meter: 92 | Not 100%, about 95% because you have to train, and all will be ok. Last month have got some problems with 6230, because after replacement charging faults ... But found, and now all ok In fact no killed phones |
01-14-2005, 09:10 | #8 (permalink) |
Member: 14259 Status: Offline Thanks Meter: 2 | Thanks for your replies. So, if I have the flash software, the UEM chip can be replaced wherever? That is to say, I can use my GSM 3100 UEM chip into my CDMA 3105 phone? BR Woods |
01-14-2005, 09:35 | #9 (permalink) | |
Member: 97820 Status: Offline Thanks Meter: 4 | Do you need new UEM chip always Quote:
Do you need new UEM chip always for replacing to make your phone . . . . . . You must see wich number your 3105 phone have and must get good for you . . . | |
01-17-2005, 01:14 | #10 (permalink) | |
No Life Poster Join Date: Jun 2003 Age: 37
Member: 30303 Status: Offline Sonork: 1001579198 Thanks Meter: 17 | Quote:
********************Azam***************** | |
1110,1112,1600 UEM can be changed? | brain00000 | Nokia Hardware & Hardware Repair | 10 | 10-26-2010 09:44 |
can i replace UEM from 1600 to 1200? | zone3 | Nokia Hardware & Hardware Repair | 0 | 11-16-2009 08:33 |
camera from E730 can be replace with other model ? | adypet1 | Samsung Hardware Repair | 0 | 03-26-2006 20:44 |
can be replace xcr3032 ? | adypet1 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 03-18-2006 13:51 |
how to replace COBBA? I think it can not be replaced by hot air gun. | sat | Nokia Hardware & Hardware Repair | 3 | 08-26-2001 23:02 |
