01-29-2014, 06:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2010 Location: b.baria. bangladesh
Member: 1215691 Status: Offline Sonork: [email protected] Thanks Meter: 43 | Ufs3 Not Update help me Active Panel Version: 2.3.0.4 Box: 1 Location: 1057 Serial: 93206 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 93206 HID: 1645F161426000A5, HWK: A1.04-PRO1 HWK: 1645F161426000A5 NOT AUTHORISED: 17, B7, Update Box Your IP: 42.0.5.105 Support: Account Ok REST: Ok UFSx: UFS3 SarasSoft, USB S/N: 93206 NVML: Ok BOOT: UFxBoot V2.2 (c) SarasSoft 2003. CORE: UFS_USB V2.8 (c) SarasSoft 2007. SERN: 93206 LIC5: True BOXK: 0 UFxBoot V2.2 (c) SarasSoft 2003., Id: 62 CF 1 10 UFS_USB V2.8 (c) SarasSoft 2007., Sn: 93206 HID: 1645F161426000A5, HWK: A1.04-PRO1 HWK: 1645F161426000A5 NOT AUTHORISED: 17, B7, Update Box Authentication stage error: Server reported error: No more upgrade logs. Please contact your reseller! |
01-29-2014, 07:23 | #3 (permalink) |
Freak Poster Join Date: Sep 2005 Age: 61
Member: 181829 Status: Offline Thanks Meter: 119 | salam, UFSx_Support_Suite_Setup_v02.03.00.04.exe 1. Uninstall ALL previous versions, you MUST uninstall HWK Suite BEFORE trying to uninstall HWK Support Suite Setup. 2. Install UFSx Support Suite Setup 3. Connect your UFSx+HWK before running the UFSx Control Panel 4. Run UFSx Control Panel 5. Switch to the "Hardware" Tab 6. If you only have one UFSx connected it will be selected, if more than one, select the check box next to the required UFSx. You can click "Scan Boxes" to refresh the list if you have connected further boxes since opening the Control Panel 7. Click "Check Box" 8. Click "Update Box" 9. Click "Check Box" - Make sure "Box Status" = "True" or "Bad Software" and "Server Status" = "Support Ok", before proceeding 10. Switch to the "Software" Tab 11. Amend "Application Install Path" and/or "Nokia Install Path", if required. 12. Click "Check Server" 13. Click "Install" 14. If you have more than 1 UFSx+HWK run steps 5-13 for each UFSx+HWK (NOTE: You must install something at step 13) How to install same UFSx+HWK to 2nd PC. Same as above and you must complete ALL steps. How to add further UFSx+HWK after initial install. Steps 4-13 as above DHLT Files Should be extracted and installed too:- C:\Program Files\SarasSoft\UFS\UFS_SAMs\_DHT for 32bit PCs C:\Program Files (x86)\SarasSoft\UFS\UFS_SAMs\_DHT for 64bit PCs |
